Old 04-11-2018, 01:10 PM   #1
leon bee
Default 8BA Ignorant Head Gasket Question
Are the gaskets interchangeable side to side? When I assembled my engine it seemed each one fit a side better than the other, but that was probably my imagination.
I had to pull a head back off, and thanks to my generous application of Coppercoat the gasket sorta pulled apart. I'll probably use it again, but I saw Felpro single gaskets offered somewhere. Thanks!
leon bee is offline   Reply With Quote
Old 04-11-2018, 01:13 PM   #2
19Fordy
19Fordy's Avatar
Default Re: 8BA Ignorant Head Gasket Question
8BA head gaskets are not interchangeable side-to-side due to the distributor and water jacket hole locations. You can see the difference here. The gasket on the top goes on the distributor side of the engine. Notice the "tab" for coolant holes.
https://www.ebay.com/i/131499851248?chn=ps&dispItem=1
Also, the 8BA head gaskets were redesigned in later years to improve coolant flow and cooling.
Old 04-11-2018, 01:14 PM   #3
fordwife
As I recall, they won't interchange side to side.
fordwife is offline   Reply With Quote
Old 04-11-2018, 01:23 PM   #4
leon bee
Thanks, guys! I figured it was maybe just me. Then I saw some singles for sale but never any reference to left or right.
Old 04-11-2018, 01:25 PM   #5
tubman
tubman's Avatar
All of them I've seen have the word "FRONT" and an arrow embossed on them. Since that logically should be "up" when the gasket is on the engine, it's pretty easy to tell left from right if you run into some singles.
Old 04-11-2018, 01:55 PM   #6
leon bee
Tubman, I remember that marking, but I been working on some off topic vehicles and "logic" doesn't always apply. I gotta say, though, dis and reassembling this 50 Ford, it is one of the most logical machines I've had.
Old 04-11-2018, 02:37 PM   #7
Ol' Ron
Ol' Ron's Avatar
I ran across something the other day. When installing aluminum heads on a block, coat the side that faces the head with a coat of Latex paint, to prevent erosion of the aluminum. sounds like simple solution of an old problem.
Old 04-11-2018, 03:09 PM   #8
flatjack9
flatjack9's Avatar
59A gaskets can interchange, but are ususally marked with an arrow. 8BA gaskets are obviously different -(different shape) and would be pretty hard to mix up.
Old 04-11-2018, 07:03 PM   #9
SofaKing
SofaKing's Avatar
You might want to reconsider using it again if it started to come apart; Higher probability it will leak.
SofaKing is offline   Reply With Quote
Old 04-11-2018, 07:55 PM   #10
rust runner
Vermont inginuity Ron
rust runner is offline   Reply With Quote
