04-07-2021, 01:12 PM | #1 |
1935 Ford Coupe meassurements , dimentions
Hello,
I could not find the information i need on internet. I got my 1935 Ford 5 window coupe in bits and pieces. A lot was cut and lost and i bought some aftermarket stuff but i realy need some information from a stock car. If someone would meassure fixed points on there ford it would be much appriciated. On the outside of the chassis between the door and rear fender there is the first bodymount, on that point it looks level, bottom chassis to ground. front tip and rear tip of chassis to ground. Front axle to chassis near the bumpstops and rear axle to chassis near bump stops. Any usefull meassurements are welcome, pictures, drawings, anything. |
04-07-2021, 01:31 PM | #2 |
Re: 1935 Ford Coupe meassurements , dimentions
Here,from Wescott
http://www.wescottsauto.com/WebCatal...ram1935-40.pdf |
04-08-2021, 02:06 PM | #3 |
thanks a lot
04-08-2021, 02:14 PM | #4 |
04-08-2021, 02:49 PM | #5 |
That is something you have to determine.
04-08-2021, 07:30 PM | #6 |
04-09-2021, 12:26 PM | #7 |
nope i'm asking from a stock 35 ford 5w coupe. not dropped not with billet wheel. STOCK HEIGHT
04-10-2021, 01:29 AM | #8 |
My avatar 3 window is unmolested 23,000 miles. What dimns do you still need?
04-10-2021, 03:32 PM | #9 |
underside chassis to ground near first bodymount . distance between axles and chassis near bumpstops.
05-03-2021, 11:32 AM | #10 |
no additional info guys?
05-03-2021, 03:39 PM | #11 |
Axle distances and bump stops was provided. The rear bump stop in centerline of the axle. Not sure on the front for that year. I guess I'm confused here. The distance between the frame and the axles, is that what your looking for?
05-04-2021, 01:30 AM | #12 |
Did you pick up my PM?
05-04-2021, 11:26 PM | #13 | |
05-04-2021, 11:35 PM | #14 | |
