03-21-2021, 08:55 PM | #1 |
1948 Ford F3
Hey all. I’m new to this forum stuff but I picked up a pickup and need some info so here I am asking. I finally got my ‘48 SRW F3 home that I bought at an auction. It’s complete and original and needs rebuilding to be drivable. Are there any differences between F2 and F3 brake systems or steering aside from 8 vs 5 lug?
03-21-2021, 09:16 PM | #2 |
Re: 1948 Ford F3
Both F3 and F2 had 8 lug hubs, as they were both 3/4 tons.
I dig coal, which provides motivation for EVs. |
03-21-2021, 09:33 PM | #3 |
Re: 1948 Ford F3
The F2 and F3 are really the same vehicle other than some additional rear springs to give the F3 a rated capacity of 6800 lbs versus 5700 for the F2. The fenders, brakes, bed, 8 lug hubs, and tailgate are identical. They are also different from the F1 - which has the 5 lug wheels - and a different hub and brake setup.
Your big challenges will be with the wheels (the F3 typically had two piece wheels dubbed 'widow makers' ) and brakes. A resource to consider is Chuck's Trucks in Connecticut. He is the go to for larger truck parts. Engine and cab parts are generally shared across the conventional F series models. http://www.chuckstrucksllc.com/
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
03-21-2021, 10:08 PM | #4 |
Re: 1948 Ford F3
Yes, all of the above... and don't mess with those widowmaker wheels.. You will find that if you have the right rear drums, some modern plain old 8 lug rims just bolt right up. Mine did. But some drums won't. Others wilkl chime in. I have nothing newer thathan the big 5 on 6 7/8" oddball tonners right now.
03-22-2021, 01:42 AM | #5 |
Re: 1948 Ford F3
Stu McMillan Marmon-Herringtons |
