02-23-2021, 01:07 AM | #1 |
New Owner
Well, I have now purchased my second Town Sedan. My first is a 1930 and now I have just bought a 1957 Fairlane 500 Town Sedan. She is not the prettiest right now to look at, and she has some mechanical issues. BUT, she only has 32K original miles and a nice power set up with a 312 and 3 sp, O/D. The interior is still in pretty good shape, but the biggest plus is that she spent her life in Fresno! So there is just surface rust in all of the usual places that I can see.
The first thing up is to degrease the inside of the engine as the valve galley has LOTS of caked on grease. What is the best way to degrease it and what should I use? Thanks, Mike
02-23-2021, 01:12 AM | #2 |
Re: New Owner
Here is the valve galley and the car.
02-23-2021, 03:28 AM | #3 |
Re: New Owner
That slug, is Horrible to get off!!
I'm building a Aug '57 dated, '58 361 Edsel engine, with the same kind of slug. I disassembled it and had it hot tanked TWICE and there was still some hard slug, inside the block, especially the oil gallery's. I spent about 3 more hours scraping slug out of small areas and wire brushing the galley's. Your oil screen will be almost, completely clogged, too. Best bet, it to tare it down and go through it. But, if your wanting to drive it, before that, pull the pan and make sure the oil screen is open, Soak the heads and valley, with grease remover then use a solvent gun to wash as much off as you can, with the pan, still off. Get the crank case area, that way, too. Blow it all down with air, replace the filter. Buckle all up and run it. Replace the filter again, after 50 miles of mostly freeway driving. DO NOT use detergent oil, it will only keep loosening the slug and clog things up. It's a VERY messy job but, may get you at least a few months of run time if, the rings are still ok. BTW, make sure that the rockers are getting oil, If not, the heads will have to come off and the passages cleaned, including into the block. I used to be a mechanic (62-70) and I put outside oilers on the Y8's and I block 6's but, I don't thing they make those any more.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
02-23-2021, 04:42 AM | #4 |
Re: New Owner
These are great looking old Fords. Great choice. With a bit of hard work, your 1957 Ford Fairlane 500 Town Sedan could look like this. |
02-23-2021, 06:35 AM | #5 |
Re: New Owner
as was said already drive as is it may go for years or rebuild it.hot tanking is the only real fix.
02-23-2021, 06:52 AM | #6 |
Re: New Owner
Does the engine run? She is dry as a bone.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
02-23-2021, 01:38 PM | #7 |
Re: New Owner
She turns over with the starter, so at least nothing appears broken. I think the plan right now is to clean and lube the living $(8&)$?!?!&; out of the engine and then lube everything else. Then fire her up to see how she runs. Work the brakes over to make her safe to drive and just get her on the road.
Mike
02-23-2021, 02:27 PM | #8 |
Re: New Owner
I agree with KULTULZ, that looks extremely dry. And that sludgey, cakey residue from the old paraffin-based oil is going to be a problem. You may get things running of course but you will never be happy with the results of cleaning no matter what you use. And once that cakey stuff releases in chunks from the engine internals you can expect clogged up oil passages. My take would be to yank the engine and completely disassemble/inspect to see where you stand - you MIGHT get away with a cleaning and go from there. It is what it is.
Lancaster, California Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan! |
02-23-2021, 07:31 PM | #9 |
Re: New Owner
I hate to pile on, but I'm afraid you really need to have a look inside it. A 312 has some value, and mainly in the crankshaft. You really don't want to gall it bad enough it won't turn for new bearings. You might try dropping the pan and seeing how it looks, then pulling the rockers. Replace and fill the pan and try priming it. See if you get oil to the heads. You'll probably have to turn the engine over (oil to the heads from the center cam bearing, depends on which "method" Ford used on those motors). If you get oil up there it's a good sign. Even then, I'd pull the heads and look close at those passages.
Here's a link to a recent discussion on cam fit, oiling etc. the last page in particular. http://forums.y-blocksforever.com/Topic155047.aspx A nice original like you've got is worth the effort. |
02-23-2021, 08:49 PM | #10 | |
Re: New Owner
02-24-2021, 02:18 PM | #11 |
Re: New Owner
The FE's have a similar oil path, in mine, the block gallery, that goes to the shallow groove, was completely pluged, even after the two hot tank dips. the first one was a full day and a 1/2, the second over 24 hours.
It sat for many years, before I bought it. Any of that slug that you don't get off, will go to the pan and detergent oil, will get it there MUCH faster. I'm with Hot Rod Reverend. take it all apart, hot tank it, if the cylinders aren't wore more than .006, put new bearings and rings in it and it will be good for many years.
02-24-2021, 03:16 PM | #12 | |
Re: New Owner
Photo 2. Oil passage thru the head and rocker arm stands to the rocker arm shaft. Diameter = 1/4 inch. |
02-24-2021, 05:46 PM | #13 | |
Re: New Owner
02-24-2021, 06:12 PM | #14 | |
Re: New Owner
But I wanted to be sure it was in good shape and not have to pull it out again. The round baffle on the oil pickup tube in the pan was sitting in sludge and it couldn't pick up enough oil, almost trashed the crankshaft, they had to cut it a fair amount. Last edited by dmsfrr; 02-24-2021 at 11:59 PM. |
02-24-2021, 09:51 PM | #15 |
Re: New Owner
Update: car fell through due to title issues. So off to the next one. Thank you all for your advice in the matter.
Mike
