04-16-2018, 05:38 PM | #21 | |
Re: valve seat cutter
R |
04-16-2018, 11:21 PM | #22 |
I'll get my hands on my friends B&D setup and see what it will take to make it serviceable.
"whatever works!" |
04-17-2018, 05:57 AM | #23 | |
I'm not sure if using a sacrificial pilot would give the same results. |
04-17-2018, 08:19 AM | #24 |
This is how runout is measured not by lapping.
https://goodson.com/products/valve-seat-run-out-gauge R |
04-17-2018, 10:48 AM | #25 | |
I went back out to the shop after thinking about what you were saying about the sacrificial guide . So I understand why it would seem to be a no no , but along your same loose fitting guide , your basically saying that a valve spring guide assembly would have the same tolerance, i.e. Sloppy , not concentric. Just because I'm new to the forum and haven't posted much , don't assume I'm new to machine shop practices . Still have most of my tooling , maybe too much as time runs out . Sorry if this is a little off , the only reason I've been on the I pad is I'm currently not feeling great , ok not even feeling good . I like the challenges and work around or tool making for the work around . No funny happy faces not acronyms, no brag , just the truth . Remember what show character said , No brag ,just fact ? Hint it was a western . Gary |
04-17-2018, 10:55 AM | #26 | |
I have learned how to email pics . Thanks , Gary |
04-17-2018, 11:05 AM | #27 |
"whatever works!" |
04-17-2018, 11:06 AM | #28 |
Links are easier, just copy and past them in.
"whatever works!" |
04-17-2018, 12:37 PM | #29 |
Pictures
"whatever works!" |
04-17-2018, 01:16 PM | #30 |
Here is a cut and paste from neway.
http://www.newaytoolsales.com/seatguiderest.htm Note they say with their setup no lapping is required. R |
04-17-2018, 01:39 PM | #31 |
I looked at the "Neway" system a couple of years ago. It looks like a good system, but with all of the parts required to do a "3-angle" valve job, the setup for a flathead was almost $500 with freight. For less than $40, I may look at the system on eBay just for giggles. (No wonder I never have any money for the "good stuff".)
It's made in India, not China. I think there may be a big difference. A couple of years ago, I wanted to buy the best metal scribe that I could, and after doing a lot of checking around, I ended up purchasing one made in India. |
04-17-2018, 01:48 PM | #32 |
Hey tub isn't it amazing where the money goes. I have been down a few rabbit holes myself.Cars,Guns,welding,fly fishing and much more.The crazy part is when you are done there is usually a box of stuff left over that doesn't have appeal even at a swap meet."LOL".
Go Jets GO. R |
04-17-2018, 01:52 PM | #33 |
Yep Ronnie, but it sure is fun, ain't it? I have advanced in years enough to be in my "puttering period" and like foolin' around with stuff like this (as long as it isn't heavy).
04-17-2018, 02:45 PM | #34 |
Stuff have a bad habbit of piling up...and to many distractions doesn´t make it easier...i like old electronics, cars and basicly anything that has some nice engineering in it...
Here´s a pic of how the neway cutters look like if your not familiar with them. And the flathead pilot corner next to the PH-2000...several generations of cutting systems from the old winona to more modern 3-angle cutters. The blade cutter on the left with a live pilot is an old VLC. |
04-17-2018, 02:52 PM | #35 |
At our shop we use a Peterson machine to install valve seats. Cutting must be exact to retain the seats in place. Nearly all blocks we see have had valve seats done over the years, so we replace all seats to restore the necessary condition.
04-17-2018, 02:55 PM | #36 |
Thanks Art for posting the pics . That's my front ( wife's garage ) overtaken by my container hurricane disaster , and a pic of an old tool , well used that Ronnies linked to .
Measuring tools are a means to the final product . If the final product is true it can be tested . Either valves with a concentric lapped seat or a crank / bearing clearance with Plastigauge Thanks again |
04-18-2018, 06:41 PM | #37 |
Is the tool on thread number 1 for sale? I would be interested in it.
04-18-2018, 10:09 PM | #38 | |
https://bellingham.craigslist.org/
"whatever works!" |
04-22-2018, 10:11 AM | #39 |
I picked up the Black and Decker set from my fiend. It doesn't have the Ford specific pilots (that replace the guide and lifter) but it does have a "collet" style pilot that fits in the guide.
"whatever works!" |
04-22-2018, 11:14 AM | #40 | |
If you don't have a "dedicated" Flathead pilot simply knurl one or two old guides for a "snug" fit in the (guide) bore and use a conventional .343" pilot, simple. Thanks, Gary in N.Y. P.S. Here's a couple shots of some pilots. The left shows a pair of "select-fit" for the Flathead guide holes, the right shows a conventional pilot with a Flathead guide. Our tops measure .437" on all our valve tooling, this is the original "Kwik-Way" size we began using for some extra rigidity!
http://www.stromberg-bulletin.com/me...berg-equipped/ |
