Old 09-11-2019, 12:53 PM   #21
adileo
adileo's Avatar
Default Re: On the horn now
Thanks all for your help.
Jerry was correct. New relay installed horn now working
Thanks
Andy
1939 Deluxe coupe
1952 F1
adileo is offline   Reply With Quote
Old 09-12-2019, 09:20 PM   #22
Tinker
Tinker's Avatar
Originally Posted by Tinker View Post
Pete, would there be an issue to damage the horn on straight battery? They should work on straight voltage momentarily. It'd be a quick way to narrow down the issue. If they work it'll be easier to clean everything off and decide the next move. Isn't the relay to boost voltage on short bursts?
Understanding relays... I'm a pre 40s guy.
Okay I read relays divert power... shut off items not used, diverting power to things being used actively, giving full power(ish). Not like creating resistance or power like a coil.
Did horn relays actually exists though on 36s? Pretty sure in 38 they did as the frame has holes for it. They included a fuse and lights.
Old 09-12-2019, 09:41 PM   #23
petehoovie
petehoovie's Avatar
Did horn relays actually exists though on 36s? Pretty sure in 38 they did as the frame has holes for it. They included a fuse and lights. .
My '34 and '37 Fords do not have a horn relays....
https://www.explainthatstuff.com/howrelayswork.html
"Silver rings, your butt! Them's washers! Damn!"
"We shot our way out of that town for a dollar's worth of steel holes." - from 'The Wild Bunch' - 1969
Old 09-12-2019, 09:56 PM   #24
Tinker
Tinker's Avatar
Thanks pete. Don't worry about hurting my feelings and just tell me right away.
Old 09-13-2019, 08:12 PM   #25
JSeery
JSeery's Avatar
Per the wiring diagrams, 1938 is the first year the cars started using a horn relay. The pickups and trucks did not use a relay until much later in time.
