Old 10-21-2018, 03:59 PM   #1
Gino
Default Whiny transmisio
Hi, I don't drive my Coupe often. Got her up for sale. Recently a friend gave her a go ( Cape Codder) he made note of the whiny Trany. I'm giving it some thought and I guees it is noisier than my 30 pickup, especially in reverse. Any thoughts thanks
Gino is offline   Reply With Quote
Old 10-21-2018, 04:57 PM   #2
Big hammer
Default Re: Whiny transmisio
Ford suggested to drain, flush, and refill the transmission I think every 1500 miles.
get a bigger hammer tap done
Old 10-21-2018, 06:36 PM   #3
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Probably just wear. Bearings, gears? If it stays in gear and shifts ok, then not worth taking it out and apart. IMO. As big hammer said , change oil and make sure it’s the correct thickness.
Old 10-21-2018, 07:34 PM   #4
Gino
I think I should say, I think this happened after I reinstalled the engine after it was worked on. But to be honest I don't recall if it made noise before but I'm sure it was not as noticeable before. This is a nice smooth running A.
I have installed at least 6 model a engines so I o have some experience.
My goal here is to identify the problem, if it is serious and willing to yank the engine if need be. I love working on them however I don't want yank the engine if it does not call for it.
Old 10-22-2018, 08:54 AM   #5
katy
katy's Avatar
Is the transmission full of oil?
Old 10-22-2018, 02:26 PM   #6
Gino
Yes the gear oil is fine. Lol I'm starting to worry that you fellers might not have an answer. Could the throw out bearing whine, sort of a high pick whine?
Old 10-23-2018, 05:27 PM   #7
100IH
They all could make noise. Likely only one.
100IH is offline   Reply With Quote
Old 10-23-2018, 07:26 PM   #8
The Master Cylinder
The Master Cylinder's Avatar
With the clutch pedal disengaged the throw out bearing should not be turning if you have the correct free play. Does it whine when the clutch is out? If so, it is not the TO bearing.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 10-23-2018, 07:31 PM   #9
40 Deluxe
Just give it some cheese to go with the whine!
Old 10-24-2018, 09:00 AM   #10
katy
katy's Avatar
Ditto
Old 10-25-2018, 07:32 PM   #11
Gino
Haha, so I think I have it figured out. So here it is, perhaps this info will help someone down the road. Bad revers idler, it is a gear in the Trany. I'll switch it out and let those who want to know what happens. Cheese makes me fart!
Old 10-25-2018, 09:14 PM   #12
Jungle Jim
Maybe it's a female transmission?
Jim :-)
Jungle Jim is offline   Reply With Quote
