Old 12-16-2017, 05:24 PM   #1
hazelhoff
hazelhoff's Avatar
Default ALU drip rails
Guys,
Once they were bent, how in earth do you take the rails apart o be drilled and mounted ?
Henk
hazelhoff is offline   Reply With Quote
Old 12-16-2017, 08:38 PM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: ALU drip rails
Some just eliminate the rain gutters & use HIDE-EM Welt instead. They make the little chrome ends, to finish them off.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 12-16-2017, 08:40 PM   #3
glenn in camino
glenn in camino's Avatar
I think I'd get it started with my pocket knife and then carefully pull it apart a little at a time.
glenn in camino is offline   Reply With Quote
Old 12-17-2017, 08:54 AM   #4
kimlinh
Hi Henk
The aluminum drip rails are a PIA. Did you use wax between the two pieces before you bent them? I gave up on mine and just mounted the piece that attaches to the car. I'm not going to drive my car in the rain(If I can help it) anyway. The steel gutters probably work better, but they were not available when In did mine
Steve
kimlinh is offline   Reply With Quote
Old 12-17-2017, 09:10 AM   #5
Sunnybrook Farm
Sunnybrook Farm's Avatar
Maybe just use the straight section and cut off the curved inner part.
Sunnybrook Farm is offline   Reply With Quote
Old 12-17-2017, 09:45 AM   #6
hazelhoff
hazelhoff's Avatar
I sincerely do not know. My body shop did the attempt. You are right they are a PIA. Steel ones are on backorder everywhere. My god why doesn't someone step into this thing. They rot away, so you would have a huge aftermarket !
I guess i'll start splitting them tomorrow. Maybe using a chisal or something. Or perhaps heating them will solve the problem ?
Thx for your help,
Henk
Old 12-17-2017, 12:29 PM   #7
BILL WILLIAMSON
Henk,
Don't feel like the "LONE RANGER", I've SEEN/HEARD HORROR stories about dealing with gutters!---As Chief would say, "I feel for you, Buddy, but I can't REACH you"!--LOL
Bill Hideemwelt
Old 12-17-2017, 02:28 PM   #8
SteveB31
SteveB31's Avatar
To seperate them, use several tiny flat bladed screwdrivers.
Regarding the comment as to why steel ones are not being made right now.
VERY small market. Also, it takes a $100,000 machine to make them, and that machine is being used to make other items more in demand. We sold those steel ones for the few years they were made, and as I recall they were around $100 pair. The aluminum ones are $25 pair. 95% of those folks given the choice bought the cheap aluminum ones.
Not a huge demand, therefore not too much of a desire to make them.
Steve @ Bert's
SteveB31 is offline   Reply With Quote
Old 12-17-2017, 02:54 PM   #9
hazelhoff
hazelhoff's Avatar
Steve, have you got any originals ? I'd liked to buy some.....
Tomorrow i will try to seperate them using everything my wife's kitchen will offer ... Haha
Henk
Old 12-17-2017, 05:26 PM   #10
Tinbasher
Tinbasher's Avatar
Get a piece of hardwood and make a couple of long tapers out of it. About 1/2" wide and 6 to 8" long. Then use a small slot screwdriver to open up the one end and get the taper in there. Then gently tap on the wedge and force the two pieces apart. Go slowly or you'll stretch the aluminum and get it out of shape.
Hope this helps. John Poole
Tinbasher is offline   Reply With Quote
Old 12-17-2017, 09:28 PM   #11
SSsssteamer
SSsssteamer's Avatar
I learned real quick not to snap the two pieces of gutter together until I was ready for final assembly. My real learning curve was how to bend them correctly to fit the roof line of my '28 Tudor sedan. I got them done and it is no show job, but it looks good. Using the original steel gutters, I did the gutters on our 1929 Tudor 50 years ago, it was a breeze, and it is of show quality too.
SSsssteamer is offline   Reply With Quote
Old 12-18-2017, 05:48 AM   #12
hazelhoff
hazelhoff's Avatar
Thank you, seems to me this will work
