04-03-2018, 11:31 AM | #1 |
gas gauge gaskets
is it a good idea to coat gaskets with sealer on both sides ? im using cork. thanks for any help, mike
04-03-2018, 11:58 AM | #2 |
Re: gas gauge gaskets
Believe it or not I've read suggestions to use maple syrup. A little drop of oil or grease wouldn't hurt.
Paul in CT |
04-03-2018, 12:25 PM | #3 |
I've only rebuilt one gauge, but it doesn't leak.
The gaskets on either side of the glass lens went on dry. A little sealer (Permatex #2) on both sides of the large cork gasket. I used two thin brass washers with a tiny bit of light oil between them.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
04-04-2018, 09:35 AM | #4 |
Rebuilt mine, no sealer, no leaks.
Hint: Do not use any parts from China for this area. You WILL have leaks!
04-04-2018, 10:47 AM | #5 |
I just did this. Use no sealer. I used the neoprene gaskets, and two brass shims lightly coated with oil. No leaks and thanks to the new glass I can see the fuel level.
1929 (early) Model A Special Coupe - restored to original 1964 Buick Wildcat convertible |
04-04-2018, 01:09 PM | #6 |
04-04-2018, 03:01 PM | #7 | |
I like using the original Ford 5Z gas gauge tool if availalble. If not use the aluminum ones so they don't mar the nuts. Larry Shepard |
