03-19-2018, 12:31 PM | #1 |
29 Repro gas cap question
Anyway, I got it to fit (I thought) and I went forward with other things that needed to be done. Yesterday I was putting some gas in the tank (which is now installed) and when I went to put the cap on I was again having some trouble threading it onto the neck. Finally I took some Vaseline and coated the cap and neck threads. That got it to work okay but it felt like the cap was not tightening down on the cap gasket. So I played around with it and I discovered that the new cap seemed to be a little different than the old cap (and I don't know if the old cap was original or not). The new cap seems to have a greater distance between the gasket and the neck of the cap--see pictures I ended up making another gasket to put into the cap--that seemed to solve the problem but I worry about the second gasket falling out of the cap some day! Anyone else have this problem with repro caps?
Why is there never enough time to do it right, but always enough time to do it over!!! |
