Old 02-12-2018, 10:05 AM   #1
jhowes
Default float valve
I have read where some people lap a float valve in using toothpaste. How do you hold the needle while lapping it in ? It seems to small to keep a grip with my bare fingers. Any ideas? Jack
jhowes is offline   Reply With Quote
Old 02-12-2018, 10:58 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: float valve
It is tough, but my drill chuck was barely able to grab it while I lapped it with toothpaste. Been leak free since the 90's.
Old 02-14-2018, 06:50 PM   #3
MikeK
MikeK's Avatar
Attach a short piece of 1/8" rod to the back end of the needle with a piece of polyolefin shrink tube. Works for me.
MikeK is offline   Reply With Quote
Old 02-15-2018, 10:17 AM   #4
DANA BIZZELL
DANA BIZZELL's Avatar
I tried new kit, polishing needle with steel wool, lapping with tooth paste with no result, finally after a year of trials tapped needle with small hammer several times, leak stopped.
Thanks
DANA BIZZELL is offline   Reply With Quote
Old 02-15-2018, 01:15 PM   #5
old31
I was able to put it in my drill press.
Old 02-15-2018, 02:11 PM   #6
Crankster
Crankster's Avatar
It may seem obvious but, make sure the right toothpaste is used. Certain "gel" types have no abrasive and will not work for this purpose. The classic old school Crest and others have an abrasive - finely ground silica - as the dentifrace or whatever it's called.
Crankster is offline   Reply With Quote
Thread Tools
Display Modes
