Old 01-28-2018, 01:35 PM   #1
oldredford
Default Ignition debate
I have 2 Model A Fords and one has the conventional point ignition and the other has the FSI electronic. I can't tell the difference in driving the cars. I know points need adjusting and electronic doesn't. I noticed the electronic starts a tad easier. Below are my own observations on pro's and con's with both ignition systems. What are yours?
Pro's for electronic. Once you set the gap you can forget about them. Easier starting, hotter spark. Maybe better gas mileage.
Con's for electronic. Cost more, have to remember you can burn the module easily like leaving the key on when motor is off and voltage spikes, these are a few things to consider.
Pro's for points, cost less, more forgiving, easy to maintain.
Con's for points. Must adjust at intervals. Some times harder to start. Weaker spark caused by the internal ballast resister in the coil.
oldredford is offline   Reply With Quote
Old 01-28-2018, 01:47 PM   #2
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Default Re: Ignition debate
Con for electronic: better know how to fix it yourself if you are out on tour and all your buddies are running standard. They all have spare parts, but not for your car.
Jacksonlll is offline   Reply With Quote
Old 01-28-2018, 02:27 PM   #3
F.M.
You can also burn out a coil by leaving the key on in an original system..
F.M. is offline   Reply With Quote
Old 01-28-2018, 05:59 PM   #4
duke36
With high compression 6.1 head , some have reported that the FS zip out of the box can't seem to get the ignition retarded enough when under load , i.e.,up steep hills , causing possible bearing issues. To remedy this, some try different advance springs or other modifications to lower the advance down from 28 deg. .
duke36 is offline   Reply With Quote
Old 01-28-2018, 06:37 PM   #5
AL in NY
AL in NY's Avatar
I have the FS Zipper distributor which has mechanical advance. I modified the advance so there is only 26 degrees total advance. I also reworked the distributor top plate and connected it back to the spark lever. I time the engine with the spark lever fully down, but now I have about 15 degrees of retard by moving the spark lever up. I did this so on a long hill climb, I can retard the spark for better performance.
AL in NY
AL in NY is offline   Reply With Quote
Old 01-28-2018, 09:26 PM   #6
Crankster
Crankster's Avatar
As well as the points, if they happen to be closed at the time.
Crankster is offline   Reply With Quote
Old 01-29-2018, 01:28 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
The same goes for the electronic ignition module, which costs more than a coil.
Old 01-29-2018, 03:46 AM   #8
3.6rs
3.6rs's Avatar
And here we go again "oldredford". This must be the fifht thread about the same subject in a few days !
3.6rs is offline   Reply With Quote
Old 01-29-2018, 05:36 AM   #9
Tom Wesenberg
Pretty soon we'll have enough thread to knit a sweater.
Old 01-29-2018, 07:04 AM   #10
oldredford
You need to correct your spelling. Fifht?
Old 01-29-2018, 07:14 AM   #11
tinman080
tinman080's Avatar
I like points, I was raised on 'em.
Just Passin' Thru.....Slowly!
tinman080 is offline   Reply With Quote
Old 01-29-2018, 07:18 AM   #12
Frank Miller
Frank Miller's Avatar
I bought quality condensors for my 49 and 66 Mustang. Both junk. I figured if I was going to go unreliable I would go with pertronix. I bought the suggested coil also. I carry a spare distributor too. Easy enough to change out. I fought hard on the decision to convert until the new condenser went bad and almost stranded me.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 01-29-2018, 07:50 AM   #13
3.6rs
3.6rs's Avatar
If you can read, write and speak my language the same as I do yours, you have the right to speak...
Old 01-29-2018, 10:20 AM   #14
Crankster
Crankster's Avatar
That doesn't make any sense?
Old 01-29-2018, 11:43 AM   #15
100IH
To most there is no debate.
100IH is offline   Reply With Quote
Old 01-29-2018, 12:35 PM   #16
Purdy Swoft
Purdy Swoft's Avatar
As far as condensers go , I don't think that it would be that difficult to rig an A&L model A condenser on later cars that uses a condenser . Make up a pig tail and connect the A&L condenser to the switch side of the coil . It shouldn't be that difficult to mount the condenser near the distributor and coil . The condenser doesn't know the difference between 6 or 12 volt . The A&L condenser just may be the only really good condenser made now days .
Old 01-29-2018, 04:14 PM   #17
Brian T
Brian T's Avatar
Hello 3.6rs,
Sometimes people have a problem with comprehension, its not the first time.
Regards Brian.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 01-29-2018, 04:45 PM   #18
Flathead
Flathead's Avatar
Probably just a typo.
Flathead is offline   Reply With Quote
Old 01-29-2018, 05:50 PM   #19
CarlG
CarlG's Avatar
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-29-2018, 07:48 PM   #20
Crankster
Crankster's Avatar
Shcolasr hvae lnog piotned otu taht splelnig wsat'n evne stnadrzied utnil teh 19th cneutry, os logn as teh frist adn lsat lttres are crrocet teh mssegae wlil get trhuogh.
