09-11-2017, 01:26 PM | #1 |
31 Slant Window TS dome light wire
I used to have a diagram of how the dome light wire in a Slant Window Town Sedan ran from the switch to the light. Does anyone have a picture of an original with the headliner out or how you replaced it?
Brian SATX |
09-11-2017, 01:53 PM | #2 |
Re: 31 Slant Window TS dome light wire
Ford service Bulletin page 468.
See attached file.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
09-11-2017, 02:02 PM | #3 |
That is it. Thanks
Brian SATX |
09-12-2017, 09:24 AM | #4 |
These photos show the dome light wire routing in my Victoria which is similar to the routing in a slant window Fordor.
The wire clips were originally made of black cardboard that looks like the backer-board of the upholstery panels. I made mine from plastic cut from empty one-quart plastic oil containers. The clamps are tacked to the wood body side rail. The original ground wire had too much resistance for my liking, so I ran a yellow ground wire to a front cowl header bolt. The dome light in my car has been converted to warm-white LEDs. Don't forget the steel wire guard over the wires dropping down to the switch. The guard prevents upholstery nails from puncturing the wires.
Bob Bidonde |
09-16-2017, 10:01 PM | #5 |
Thanks Bob, great info as usual
Brian SATX |
09-23-2017, 01:10 PM | #6 |
Do you have a picture of the dome light mount frame? I found one at an old junkyard that says '31 slant town sedan...but can't seem to get it to fit right. Wondering if it's misidentified. Made my own but would like to get a correct one in there. You can see my homemade one...last pic.
09-23-2017, 01:31 PM | #7 |
This is home mine is mounted in my 31 SW 4D TS.
Thanks, |
09-25-2017, 09:36 AM | #8 |
These pictures show the dome light in my Victoria. The installation of the wood light mount is the same as in the slant-windshield Fordor.
Bob Bidonde |
09-25-2017, 02:56 PM | #9 |
Where is it grounded to from the factory?
According to that diagram PDF, the rear quarter panel?
1931 Murray Town Sedan. Black body with Apple Green pin stripe. 1923 Model T Touring with electric start. Low radiator Cincinnati, Ohio |
09-25-2017, 03:59 PM | #10 | |
09-26-2017, 10:18 AM | #11 |
The dome light on the right is for slant-windshield Victorias and Fordors, and the one the left is for straight-windshield Fordors. The second photo shows the backside of the dome light mount. These photos were copied from the internet, but I don't when or where.
Bob Bidonde |
09-26-2017, 01:36 PM | #12 |
The first photo showing the two styles of dome lamps is my photo, from one of my old ads in the FordBarn Swap Meet section. In case someone is interested, I still have several original dome lamps available, just haven't advertised them lately. I also have extra original lenses and parts in case someone just needs a part and not a complete lamp assembly.
