01-13-2020, 09:15 AM | #1 |
How did you do the link cords on your LED's??
I just started switching over to high bay LED's and was wondering what or how you "tiddied" up the link cords to eliminate the "saggy" cords??? A little "before" & "After"........suggestions?????
01-13-2020, 09:19 AM | #2 |
Re: How did you do the link cords on your LED's??
Could you tidy it up by running the cords through PVC pipe?
01-13-2020, 09:28 AM | #3 |
I just doubled them back on themselves and wrapped with a couple small tie wraps; but I also was able to clamp the bundle to my sheet rock ceiling.
01-13-2020, 09:29 AM | #4 |
I thought about that BUT wondered IF the "excess" being "bunched up" somewhere along the length "might" cause an issue......currently that's my first approach to test out tonight. My other thought IS I hate to have the weight of the PVC resting on the "plug" ins as they are not the beefy-ist of connections and not sure how to secure it to the light housing???? Thought I might "cast it out" here on the barn and "see if" there were any other "clever" solutions. Thanks 19Fordy!!!!
01-13-2020, 09:53 AM | #5 |
Red colored fuel hose?
Sorry about that. But I'm trying to think of some lightweight tubing that is basically a scaled-up drinking straw but long and stiff enough to span the gap. Even something like that might be junk after several years.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
01-13-2020, 10:05 AM | #6 |
01-13-2020, 10:33 AM | #7 |
Here Ya' go all "tiddied"
01-13-2020, 11:14 AM | #8 | |
01-13-2020, 08:59 PM | #9 |
One safety issue, need eye protection for the dog. Sunglasses.
Nice shop. Bruce
Works good Lasts long time |
01-13-2020, 10:26 PM | #10 |
we are in the process of putting led's in a spray booth, I am worried that if we use two per bay ( 2 x 4") it will be too bright!
01-13-2020, 10:36 PM | #11 | |
Thats exactly what I did in my shop also the garage at home and all the basement lights converted everything to LEDs amazing improvement. Also a decent savings on the electric bills another benefit. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
01-14-2020, 07:44 AM | #12 |
Thanks cmbrucew for the compliment on the shop.....Still getting a little of the old junk from the last owners cleared out and still working on how I want it set up before a "few" more V8's arrive. "Oliver" is one of two "Shop Dogs" if you will BUT not sure "Momma" will let them stay out in the shop long before she calls them back in for their daily pampering and A/C as its been in the 80's the past several days and a few more to come!!!
