Old 11-26-2019, 10:32 AM   #21
Jeff/Illinois
Jeff/Illinois's Avatar
Default Re: New Radiator and Losing Coolant
Losing that much coolant due to a blown head gasket or a cracked block, it is going to show up at the tailpipe as tell- tale white smoke and you will be able to smell the anti-freeze burning out. It is an indistinguishable odor.
Two gallons in such a short amount of time especially, is extremely excessive. Since it's not puddling out on the floor it has to be burning off. Hopefully not a cracked block, just the bad head gaskets like has been spoken of here before.
Old 11-26-2019, 06:06 PM   #22
1931 flamingo
1931 flamingo's Avatar
Pull the spark plugs. What color are they??
Paul in CT
Old 11-27-2019, 11:24 AM   #23
Will N
Will N's Avatar
I was losing coolant, and I attributed it to it going out the overflow during highway runs. But I found that the water pump would leak only while the engine was both warm and running. Never leaked a drop when you would first start it up, or when you shut it off. The leak was slow enough that it would evaporate on the hot engine block, so I wasn't leaving a trail of coolant. Found it by accident when I left the engine running at a gas stop and opened the hood. It was one of those "leakless" water pumps. Replaced it and coolant loss problem is gone.
Will N is offline   Reply With Quote
Old 11-27-2019, 12:23 PM   #24
30 Closed Cab PU
Paul in CT
What do plugs look like if coolant getting into the cylinders? Different looking if using water vs. antifreeze?
Old 11-27-2019, 12:34 PM   #25
ryanheacox
ryanheacox's Avatar
If it's "burning" enough water/coolant the plugs and combustion chamber should look nice and clean. Might look slightly different with coolant vs water.
Old 11-27-2019, 03:39 PM   #26
30 Closed Cab PU
So sounds like the same as the trick of a water misting bottle through the air intake or vacuum port at fast idle.
Thanks, was unsure if results would be the same.
Old 11-27-2019, 07:40 PM   #27
redmodelt
redmodelt's Avatar
Done the water thing on my Model T a few times. Sure cleans things up!
