04-08-2020, 05:13 PM | #1 |
46 woody door skins
Do the doors for the woody have to be disassembled to insert the outer door panels? I made templates to make these outer panels. Unfortunately I used a little thinner material than the original thickness panel, they worked BUT I had to wrestle the templates in. I thought I could get completed final panel in with a little work. NOT SO, what is the trick of getting these in the door? Thanks!
04-08-2020, 05:35 PM | #2 |
Re: 46 woody door skins
No, but It's a real pain, because you need to literally bend them to fit into the mortise. You need to trim them a little smaller to get them to fit.
04-08-2020, 05:48 PM | #3 |
Thanks!! Pain is understatement
04-08-2020, 07:25 PM | #4 |
A related question, I want to replace the inside door skins on my 47 Woodie, as what is there now is just unattractive board. Any source for best wood replacement to get close to original? Thanks. Digger
Photo from today along Asilomar, although there are signs to GO HOME AND STAY HOME! |
04-08-2020, 08:09 PM | #5 |
Digger, you're located in CA, you have Ron Heiden, Wood N Carr among others in CA, that can supply you with what you need.
04-08-2020, 08:17 PM | #6 |
04-08-2020, 08:33 PM | #7 |
Robert Johnson is also in the Bay area.
04-08-2020, 08:37 PM | #8 |
Do you have contact information for Robert Johnson? Thank you
04-09-2020, 11:34 AM | #9 |
Robert Johnson Restorations
60 Clausing Court Novato, Calif. 94945-4107 415-827-0524 |
