02-06-2020, 12:50 PM | #21 |
Re: Aluminum Flywheel
Since we are on the subject of aluminum flywheels. Are there two different Albro models. One for early flat heads and one for 8ba's?
02-06-2020, 03:29 PM | #22 | |
Joe the pilot bearing hole in the aluminum flywheel should be the same as the stock Ford Flathead. The 203 bearing fits all of the aluminum flywheels as well as the stock Ford flywheel perfectly. At least the many I have had my hands on. Its possible the speedway item is not correct which would not be a surprise to me. I can measure the T-5 input shaft pilot size and let you know for sure if the ID of the 203 bearing will work memory tells me it will but I can check for sure since I have everything available in my shop. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
02-06-2020, 05:30 PM | #23 | |
02-06-2020, 05:32 PM | #24 |
02-06-2020, 05:39 PM | #25 | |
I'm concerned the hole in the flywheel is to large, but I haven't got an exact measurement on it yet. I sure hope not, I have some money invested in it with redrilling and balancing! I sent an email to Ram, but haven't heard from them. I wonder if anyone makes one oversized? Thanks, Joe |
02-06-2020, 06:37 PM | #26 |
Then I remeasured the pilot bearing and it's 1.572. Seems like that may be the problem. I don't know if I can get a bearing with a better measurement. Any thoughts? Thanks |
02-06-2020, 09:48 PM | #27 | |
Ronieroadster
02-07-2020, 04:01 AM | #28 | |
02-07-2020, 05:40 AM | #29 |
The stock Ford bearing is metric. It is 40mm. 40mm = 1.5748".
You need to try another bearing. If this is an adaption all bets are off. |
02-07-2020, 03:21 PM | #30 |
Joe measured a few items today first the Ford bronze bushing measures 1.573 the one I measured was used. Also have the Speedway pilot bearing in stock for a build Im doing for someone the bearing is for the T-5 transmission Speedway part number 916-29520 should be the same as the bearing you have from them the OD on the bearing is 1.574. I also measured a used aluminum flywheel the bore diameter for the bearing measured 1.572. Seeing all of this i would agree theres a problem with the bearing hole in your aluminum flywheel. If I was doing this and ran into the problem you have i would bore out the flywheel hole a bit then machine an aluminum bushing to fit as needed I would include a flange on this bushing thats located on the clutch side of the flywheel. To be certain the bushing remains in the flywheel i would simply add a few small Tig welds to the bushing to be sure it stays in place. The material added is so close to the crank center-line you will never notice any balance issues ever in your application.
. Ronnieroadster
02-07-2020, 06:48 PM | #31 | |
Thanks again, Joe |
02-07-2020, 08:29 PM | #32 |
The original size bearing [6203 2RS] is 40mm od 17mm id 12mm deep
If you need to pay a machinist to bore and sleeve your flywheel back to size, you might find this is a cheaper option; get the machinist to bore flywheel to 42mm. Fit a 6203A/42-2RS bearing which is 42mm od.
02-07-2020, 10:42 PM | #33 |
What's the advantage of a aluminum flywheel outside of circle track or drag racing?
02-07-2020, 11:23 PM | #34 |
Tinker asked "What's the advantage of a aluminum flywheel outside of circle track or drag racing? "
Bragging rights |
02-07-2020, 11:42 PM | #35 | |
1-Saftey. 2- Makes shifting much easier. 3- Ruduces torsional vibration in the crank when used with the proper front damper. 4- Reduces overall weight of the car thus enhancing performance and gas mileage. |
02-07-2020, 11:51 PM | #36 |
Pete I know you know your stuff.
To me the weight of the flywheel has some play in overall performance. The lighter it is the quicker it spins up. Good for race. It also does not maintain momentum. A heavier flywheel is good for street use or driving. Not sure a aluminum flywheel is safer for street use. Maybe drag, without a shield? All is valid for a race car not a street car. A heavier flywheel is good for a street or tour car. It creates momentum. Or I'm wrong. I'm okay with being wrong. . |
02-08-2020, 06:13 AM | #37 | |
Thanks, Joe |
02-08-2020, 02:48 PM | #38 |
You could always go with a bushing. A lot of people prefer the bushing anyway.
02-08-2020, 02:59 PM | #39 | |
02-09-2020, 12:46 AM | #40 |
I would like to have one of those flywheels that create momentum.
We are talking perpetual motion now. |
Thread Tools | |
Display Modes | |
