Old 04-19-2013, 06:20 PM   #1
jimloiselle
Default cleaning sludge from oil pan
Hi you all, Need a good way to clean the A model oil pan. My repair book says to pry the baffle tray out of the pan. But that looks hard to do without damaging the tray. Is this correct? If so, whats the best way to remove the tray. Thanks
jimloiselle is offline   Reply With Quote
Old 04-19-2013, 06:24 PM   #2
chopo
Default Re: cleaning sludge from oil pan
i put my hand in the oil pump opening and lift. it snaps in/out not too bad to get out. wear gloves
www.jalopyshowdown.com
dont scare me i poop easy
chopo is offline   Reply With Quote
Old 04-19-2013, 06:25 PM   #3
MikeK
MikeK's Avatar
Slam it flange side down hard against the ground. It pops out. Warning! Expect sludge spatters.
Mechanical engineering 101: If you put an adjustment knob, screw, bolt, or tolerance specs on something, some people will immediately fiddle with it. If you mark it DO NOT TOUCH everyone will mess with it.
MikeK is offline   Reply With Quote
Old 04-19-2013, 06:27 PM   #4
Mitch//pa
what mike k said
Old 04-19-2013, 06:30 PM   #5
160B
160B's Avatar
I take the handle from a sledge hammer w/o the hammer, put it in the oil pump hole and pop the tray out of the pan. works every time
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 04-19-2013, 07:09 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
One of the first things I learned when I joined the local Model A club was the slamming on the ground to remove the dipper tray. It works every time, but like Mike said, expect some splatters.
Old 04-19-2013, 08:15 PM   #7
1932BB
Spread the pan sides slightly with a 2x2 between the bolt flanges near the center. The tray will pry out easily. Easy does it!
1932BB is offline   Reply With Quote
Old 04-19-2013, 09:26 PM   #8
jimloiselle
Got it out! Thanks for all the tips. Jim Loiselle
Old 04-19-2013, 10:02 PM   #9
zzlegend
zzlegend's Avatar
Hey Jim. I just cleaned the sludge out in one of my engines last week. Messy job but worth it. You might want to pull the valve cover also and clean in there. Mine was very sludgy in there to. Good luck with it. Mark.
zzlegend is offline   Reply With Quote
Old 04-19-2013, 11:06 PM   #10
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
WARNING, before cleaning the oil tray, locate the gravity flow oil passages & plug them with fat pipe cleaners & remove them AFTER the cleanup. If sludge is pushed down in a passage, it might plug it up & destroy a main bearing or a cam bearing. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-20-2013, 12:02 AM   #11
Geo. H
C'mon guys. Just put the pan in your wife's dishwasher. No need to take the tray out.
Geo. H is offline   Reply With Quote
Old 04-20-2013, 12:16 AM   #12
Mike V. Florida
Mike V. Florida's Avatar
Single now huh.
Old 04-20-2013, 02:33 PM   #13
Mikeinnj
Mikeinnj's Avatar
Wrap the pan in a large black garbage bag , then slam it on the ground; there will be no splatters.
Mikeinnj is offline   Reply With Quote
Old 04-20-2013, 09:10 PM   #14
Paul from Maine
Paul from Maine's Avatar
The garbage bag is a Great and simple idea! Never thought of that! I put something with give like a few layers of corrogated cardboard or that old fiber wallboard on the barn floor next to the stairway, go up a couple of steps and drop it on the flanges. Little or no splatter and easy on the flanges. Doesn't kill the grass or pollute the water supply either!
Paul from Maine is offline   Reply With Quote
Old 04-22-2013, 12:36 AM   #15
Special Coupe Frank
Special Coupe Frank's Avatar
Working on spare '29 engine: dipper tray just fell-out when I turned the pan upside-down...
Is there an reason the dipper tray needs to be a tight-fit ?
SC Frank
Special Coupe Frank is offline   Reply With Quote
Old 04-22-2013, 01:02 AM   #16
Mike V. Florida
SC Frank
Hit a bump in the road the dripper tray jumps up hits the moving connecting rods, bends up the tray which hits more rods, snaps the oil pump, no oil to the engine all hell breaks loose and you buy a Shay to solve the problem in the future.
