Old 04-08-2021, 09:38 AM   #1
Steve Plucker
Default Front fender bracket to frame bolts...
Just what was the correct bolt attachment of the Front fender bracket to the frame?
Was it nuts to the outside or nuts to the inside?
I want to say say nuts to the inside on 1929 thru 1931 without Castel nuts...But what about the 1928's when Castel Nuts were used? Nuts to the inside or nuts to the outside?
Thanks.
Pluck
Old 04-08-2021, 10:25 AM   #2
Roadster62
Roadster62's Avatar
Default Re: Front fender bracket to frame bolts...
Nuts to the outside would make assembly a lot faster IMO.
Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 04-09-2021, 10:12 AM   #3
Neil Wilson
Neil Wilson's Avatar
Thanks.
Pluck
Based on my research:
Front Fender Bracket Fasteners (bracket to frame)
Forged Brackets – One 1/2-20 x 1-9/16 bolt and two 3/8-24 bolts. Through April 1928, the bracket to frame bolts used castle nuts facing outward with cotter pins. Also, starting in early 1928 hex nuts with lock washers were used with bolt heads facing outward (note usage date overlap). Bolts were cadmium plated into late 1928 and gloss black thereafter. Cotters were unfinished. Nuts were unfinished into late 1928 and zinc plated thereafter. Lock washers were unfinished.
This is at https://aafords.com/aa-chassis/aa-16000-fenders/#ffas
[email protected] - email contact
https://aafords.com Ford Model AA Truck Club @ aafords.com
Neil Wilson is offline   Reply With Quote
Old 04-10-2021, 09:04 AM   #4
KenBolton
I’ve always been told “nuts go you”!
KenBolton is offline   Reply With Quote
Old 04-10-2021, 09:12 AM   #5
Steve Plucker
Thanks guys.
Pluck
