Old 06-15-2020, 08:58 AM   #1
ford35lh
Default 35' gas tank ID
Is there a way to tell if a gas tank is for a 35' panel ???
Found a guy who has a barn full of all sorts of gas tanks and has
about a dozen that look very close to online photos.
My panel's tank had absolutely no bottom so I removed the filler pipe
and sending unit and discarded it 30 years ago when I dismantled
the truck. Dumb move on my part.
ford35lh is offline   Reply With Quote
Old 06-15-2020, 09:14 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: 35' gas tank ID
take your sending unit---up to 35 was hydrostatic, 36 was electric, different size, if you find a tank your sender fits it is at least 35 or earlier---
Old 06-15-2020, 10:35 AM   #3
DavidG
DavidG's Avatar
Which panel delivery version do you have, the 112" wheelbase commercial version or one of the larger versions on truck chassis?
DavidG is online now   Reply With Quote
Old 06-15-2020, 10:58 AM   #4
Don Rogers
Don Rogers's Avatar
Ford 35, If you have the 112" wheelbase panel delivery, then it is the same tank as used in the 35 pickup. 35 tanks have a small hole on top to receive the 35 hydrostatic gas sending unit. The panel/pickup tank will have a different filler neck connection than the passenger car doe that year. See enclosed photos.
Don Rogers is offline   Reply With Quote
Old 06-29-2020, 11:46 AM   #5
ford35lh
Getting caught up on work and back on this tank.
Here are photos of the tank I have with my 35' 112" panel
filler pipe mocked up in its position.
Next question;
Suggestions on the least invasive way to get the elbow inside ??
Thread Tools
Display Modes
