02-21-2020, 06:42 AM | #1 |
35 Front End Alignment
I need help determining the best method of establishing the correct front end
alignment on my 35. A step by step process will be greatly appreciated as I haven't come across any literature explaining the method on an old Ford. |
02-21-2020, 07:55 AM | #2 |
Re: 35 Front End Alignment
Peter,
It is covered extensively in the 1935 Service Bulletins, including photos. |
02-21-2020, 08:56 AM | #3 |
Dave,
Thanks for the information. Peter |
02-21-2020, 09:03 AM | #4 |
Peter: Google, 1935 Ford front end alignment . Lots of good info appears.
02-21-2020, 01:50 PM | #5 |
Sorry guys I’m new with this 1935 service bulletins
Where do I find that info. |
02-21-2020, 03:06 PM | #6 |
02-21-2020, 03:06 PM | #7 |
Even more is in the 1936 service bulletins, they changed to a fancy drive on rack that worked in degrees, and toe setting that factors in camber, much like modern machines
02-21-2020, 07:10 PM | #8 |
Thanks for your responses a David and Kurt
02-21-2020, 08:29 PM | #9 |
Here's the chart from the service bulletins--- the whole article it nearly 10 pages. Explains every part of aligning
02-22-2020, 06:00 AM | #10 |
Thanks to all who responded. For now I'll try one of the methods I googled but
when I finally get her on the road I will have it professionally aligned as I plan on reproducing a correct non adjustable draglink so no turning back once I declare myself on the length of that. Peter |
02-22-2020, 11:36 AM | #11 |
Peter, I have a hardcover book with a date of 1936. It says, Ford Service School, wheel alignment. Measures 5 1/8 x 7 1/4 , 63 pages. Just about all you would ever need to know to get your job done. You might find it online someplace ?
