Old 11-05-2019, 09:39 AM   #1
Big hammer
Default MMO non believers
The last two tanks of gas was 100% gas, at least what I paid for. The gas shut off valve had been very hard to turn. Last tank I put some MMO in and then let it run for awhile before closing the valve and letting it run dry. This last weekend drive the shut off valve turned free like new! Also the dripping carb stopped dripping gas at idle! I believe the carb float valve was sticking and needed some cleaning and adjustment but now is working great! Just at the end of this driving season :-(
get a bigger hammer tap done
Old 11-05-2019, 10:00 AM   #2
WHN
Default Re: MMO non believers
Wait and see what it will do for noisy valves.
You can lead a horse to water but you can’t make it drink. Enjoy.
Old 11-05-2019, 10:17 AM   #3
alexiskai
alexiskai's Avatar
What proportion or amount are you putting in? I know it's different when you use it in the oil vs in the gas.
Old 11-05-2019, 10:29 AM   #4
WHN
4 oz. for 10 gallons in gas.
A little more or less seems not to matter.
Old 11-05-2019, 10:48 AM   #5
Aretino
Been using MMO for 40 years. Initially used to lubricate my aviation air tools. Since the advent of ethanol laced fuels I find that MMO also helps alleviate the problems with fuel system corrosion. Recently I added MMO to my 2005 4runner with hopes that a false fuel quantity issue might be rectified. After two tank fulls of fuel with MMO (4oz/ 10gal) my fuel tank sensor issues have improved. I feel MMO is a great preventative maintenance additive.
Aretino is offline   Reply With Quote
Old 11-05-2019, 10:54 AM   #6
Beater
Beater's Avatar
MMO is great stuff I love it. 2 cycle oil will also help out things, but not as good as MMO
Beater is offline   Reply With Quote
Old 11-05-2019, 10:55 AM   #7
harryc
I have an unused gallon MMO that's been setting in my garage for at least 35 years. Do you think it's still roadworthy?
harryc is offline   Reply With Quote
Old 11-05-2019, 11:03 AM   #8
30 Closed Cab PU
I use it, but only in a couple of tankfuls per year. When I was using it every tankful, experienced increased deposits on my spark plugs. A couple of others have also experienced this.
Old 11-05-2019, 12:52 PM   #9
J Franklin
J Franklin's Avatar
If you don't want it I'll use it!
Old 11-05-2019, 01:01 PM   #10
1931 flamingo
1931 flamingo's Avatar
ATF is an alternative and less expensive. FWIW
Paul in CT
Old 11-05-2019, 01:04 PM   #11
Patrick L.
Patrick L.'s Avatar
OK. So a fair test would be to allow the car to go back to its old maladies and then try a different fuel additive and try to then make a comparison.
Just kidding, couldn't resist.
Old 11-05-2019, 01:35 PM   #12
Beater
Beater's Avatar
Paul in CT
about the only thing ATF has in common with MMO is the color
Old 11-05-2019, 01:40 PM   #13
Werner
Werner's Avatar
I certainly do not think so! Comparisons:
ATF is thicker, contains high pressure additives, contains coefficient of friction enhancer; it is not suitable for engine combustion. (Residues).
MMO contains u. a. petroleum, solubilizers, detergents, dispersants, ester oils, PAO.
Only the red color has these two liquids in common.
Werner
Ford Model A Roadster, 1928
Citroen 11 CV, 1947
Honda CB 450 K 1, 1968
Hercules Wankel Rotary Engine, 1976 (Canadian version)
Werner is offline   Reply With Quote
Old 11-05-2019, 01:43 PM   #14
oldforder
oldforder's Avatar
I have been using MMO since I was a teenager (60 years ago) in every vehicle and tractor, and small engine. Except the NEW vehicles. Don't how much good its does, but It sure don't hurt.
oldforder is offline   Reply With Quote
Old 11-05-2019, 02:11 PM   #15
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I’ve told the story before. When my engine was new I had a tick in it. The builder told me to put Marvel mystery oil in the gas. I did, and the tick went away. The next tank I didn’t put it in and the tick came back. I’ve been using it ever since.
Old 11-05-2019, 02:20 PM   #16
M2M
M2M's Avatar
MMO's placebo effect is real.
M2M is offline   Reply With Quote
Old 11-05-2019, 02:26 PM   #17
woofa.express
woofa.express's Avatar
Hi M2m. If it works, great. If it’s placebo effect, well that’s great too. That's called a win win situation.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 11-05-2019, 02:52 PM   #18
Dodge
And yes on your 35 yr. Old MMO
Dodge is offline   Reply With Quote
Old 11-05-2019, 11:32 PM   #19
dumb person
dumb person's Avatar
Can't get MMO in my country so i use A.T.F. sometimes.
Smells a bit funny but it does cushion the valves nicely & lubes the stems & tap.
Also seems to reduce the piston slap sound by cushioning them against the cylinder walls on their way up.
Laugh if you want but it's all true.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 11-06-2019, 12:11 AM   #20
Synchro909
Synchro909's Avatar
I've never seen MMO here either. I use Flashlube which is made buy a f riend of mine. It is a lead replacement compound that lubricates as well. 1 ml in a litre.
For the first half of our life we trade our health for wealth. For the second half, we trade our wealth for health.
