Old 07-12-2019, 06:16 AM   #1
Jensen S1
Jensen S1's Avatar
Default Jensen S1
Hi
I want to introduce myself here.
I bought the first ever build car from Jensen Motors Ltd. last year. Now in the process of a full rebuild.
The car is a interesting one off, not comparable in any detail with the serial production cars.
Running gear is 1934 Ford (engine, gearbox and rear axle), custom made chassis and alloy body over ash frame.
Home of the first ever build Jensen, made 1935 in West Bromwich England, powered by the good old Ford Flathead V8
Jensen S1 is offline   Reply With Quote
Old 07-12-2019, 06:35 AM   #2
KiWinUS
KiWinUS's Avatar
Default Re: Jensen S1
WOW Great car
Welcome to the Barn
Old 07-12-2019, 07:08 AM   #3
tubman
tubman's Avatar
Looks to be in pretty good shape. Good luck with your project and try to keep us informed of any progress.
Could that car be the one-off they made for Clark Gable?
Old 07-12-2019, 07:19 AM   #4
skidmarks
skidmarks's Avatar
Motor looks like a 59A and the coil makes it look like it has a crab distributor cap
skidmarks is offline   Reply With Quote
Old 07-12-2019, 07:21 AM   #5
JSeery
JSeery's Avatar
Looks like an interesting project! Welcome to the Barn.
Old 07-12-2019, 08:28 AM   #6
flatheadmurre
flatheadmurre's Avatar
That´s a real nice looking car.
Engine and radiator must have been changed during the years...it´s a 38 or newer but sparkwire looms are still the early -36.
Old 07-12-2019, 12:28 PM   #7
19Fordy
19Fordy's Avatar
That is truly a very beautiful car. Congrats on getting it.
Can I assume they Jensen later became Jensen-Healy?
Old 07-12-2019, 12:32 PM   #8
Darrell S
Darrell S's Avatar
That is a very unusual rear door configuration, how does it work?
Darrell S is offline   Reply With Quote
Old 07-12-2019, 12:34 PM   #9
rich b
rich b's Avatar
Pretty fancy home for a flathead; I like it!!
Old 07-12-2019, 12:44 PM   #10
tubman
tubman's Avatar
The rear cowl is pivoted at the front and flips forward; open the door, and (awkwardly) step in and take your seat. Then you close the door and fold the cowl back down.
Old 07-12-2019, 12:55 PM   #11
ford38v8
ford38v8's Avatar
Welcome to the Ford Barn! That's a beautiful automobile! Your engine and radiator does appear to have been replaced with a later vintage. If you plan on restoring the running gear to its original state, you'll find plenty of help on this forum.
To another's question regarding the 3rd door, I've seen those small storage cubbies intended for golf clubs and such.
Alan
Old 07-12-2019, 01:58 PM   #12
38bill
38bill's Avatar
I like the flip top oil fill on top of the fuel pump stand..
38bill is offline   Reply With Quote
Old 07-12-2019, 02:01 PM   #13
petehoovie
petehoovie's Avatar
Unique....
"We shot our way out of that town for a dollar's worth of steel holes." - from 'The Wild Bunch' - 1969
Old 07-12-2019, 03:50 PM   #14
Jensen S1
Jensen S1's Avatar
Thanks for the warm welcome.
The engine was swapped in 1957. When the car was shipped from England to Canada they didn’t drain the cooling system and as a result of the very low temperatures on a December Atlantic crossing the block cracked. I was told that they swapped in an engine from the 40s but kept all auxiliary’s.
I will have many questions indeed.
Joerg
Old 07-12-2019, 04:27 PM   #15
34fordy
34fordy's Avatar
What would "alloy body and ash frame" be?
34fordy is offline   Reply With Quote
Old 07-12-2019, 05:56 PM   #16
19Fordy
19Fordy's Avatar
I bet it's aluminum with a wood frame.
Old 07-12-2019, 06:17 PM   #17
alanwoodieman
aluminium as "alloy" is also called in the UK
ash is a very tight grained, flexible wood used in frames for Morgans and baseball bats
Old 07-12-2019, 06:34 PM   #18
34fordy
34fordy's Avatar
It appears that the firewall is riveted to the cowl. If so, I wonder where else this is done on this beauty.
Old 07-12-2019, 07:58 PM   #19
TJ
TJ's Avatar
Nope, not even close. The Gable car had a '36 Ford front end and the remainder of the body was totally different.
TJ is online now   Reply With Quote
Old 07-12-2019, 08:05 PM   #20
35fordtn
35fordtn's Avatar
Very neat car... if it is a 34 chassis, I am intrigued as to what hubs/brakes it has to adapt those wheels. I’d love to see a photo of the dash panel as well!
