Old 11-02-2013, 03:47 PM   #1
Zeke...PA
Zeke...PA's Avatar
Default Ignition steering lock disassemble
35-36 ignition steering lock assembly, any easy way to remove the small pin which activates the ignition switch from the slide lock. It has to come out to completely disassemble. Lock is already out. Got Don's write up, he just says remove the pin, problem is the pin doesn't want to cooperate. Thanks Zeke
Only problem with retirement is never a day off
Zeke...PA is offline   Reply With Quote
Old 11-02-2013, 04:07 PM   #2
oldford2
oldford2's Avatar
Default Re: Ignition steering lock disassemble
Here is a post for later models. Don't know if it covers your lock. Take a look.
http://fordbarn.com/forum/showthread...=lock+cylinder
John
oldford2 is offline   Reply With Quote
Old 11-02-2013, 06:23 PM   #3
DavidG
DavidG's Avatar
Use a small pair of vise-grip pliers on the pin and a screwdriver to lever around the tips of the jaws of the pliers and the pin should pull right out.
Old 11-02-2013, 06:58 PM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
Zeke, here is a post that has instructions with sketches on how to take a '35-'36 column drop apart. Don Rogers originally posted this information.
https://www.fordbarn.com/forum/showth...ht=column+drop
Also, if you do a search for "column drop" you will find some other good posts on the same subject.
John
Old 11-03-2013, 11:51 AM   #5
32phil
DavidG has it exactly right. To replace it, just tap it back in place, the "bite" marks from the vice grips should not matter.
Early Ford Lock & Key Service
https://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 11-04-2013, 04:24 PM   #6
Zeke...PA
Zeke...PA's Avatar
SUCCESS, thanks the vise grips did the trick, Zeke
Old 01-08-2014, 05:52 PM   #7
Init1
Init1's Avatar
Did you get that pin out? Just did mine with a vise grips and a tug and it came right out. It is just pressed in.
Init1 is offline   Reply With Quote
Old 01-08-2014, 06:41 PM   #8
Don Rogers
Don Rogers's Avatar
Just revised my instructions to include use of vice grips. Sorry for the omission.
Don Rogers
Don Rogers is offline   Reply With Quote
Old 01-08-2014, 10:33 PM   #9
Phil Gillespie
Phil Gillespie's Avatar
Presume this would also cover for 34 Set Up also?
Phil
NZ
Phil Gillespie is offline   Reply With Quote
Old 01-08-2014, 11:17 PM   #10
Sivarti
You're giving me hope. My Saturday project is to free up mine. Loading it with the steering locked up sucked.
Sivarti is offline   Reply With Quote
Thread Tools
Display Modes
