10-20-2019, 06:51 AM | #1 |
Rams Horn Bolts
Hello folks. Anyone have a source for the header bolts for rams horns on a 272? They are two different lengths. I found one vendor (CJs), but they are out of stock. Thanks, Glenn
Glenn ‘56 F100 272 Pacific Northwest |
10-21-2019, 09:15 AM | #2 | |
Re: Rams Horn Bolts
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
11-02-2019, 12:57 PM | #3 |
Re: Rams Horn Bolts
I don't recall there being anything special about the exhaust manifold bolts for a Y-block.
I would suggest ARP as a source for good high quality bolts. Victor/Macord use to make a very good gasket w/heat shield for the rams horn type of exhaust manifolds.. Keeps the oil in the rocker arm area from cooking. The rams horn manifolds are very prone to coming loose if you use poor quality bolts. If you can find a set of rams horns for a '55-57 T-Bird with dual exhaust you can eliminate the front cross over pipe on your Y-block. The left had manifold will have a rear drop in lieu of the front. I have the part number for the Bird manifolds.
Bill.... 36 5 win cpe Last edited by blucar; 11-02-2019 at 01:03 PM. |
11-02-2019, 07:32 PM | #4 |
Re: Rams Horn Bolts
Use ordinary bolts - those bolts were nothing special. Just make sure the ones you get don't bottom out in the hole.
11-03-2019, 09:28 AM | #5 | |
Re: Rams Horn Bolts
What if the OP wants a dressed engine? Look a lot better than HOME DEPOT CHI-COM.
11-03-2019, 09:38 AM | #6 | |
Re: Rams Horn Bolts
Still available - Notice that they also incorporate the spark plug heats shields. Two birds with one stone TECH.
