01-31-2018, 05:19 PM | #1 |
Brake shoes
What us the difference between Model A brake drum and hydrolic brake drum for a Model A?
Thanks in advance. Charles |
01-31-2018, 05:20 PM | #2 |
Re: Brake shoes
I meant to say Brake drums.
01-31-2018, 08:09 PM | #3 |
Re: Brake shoes
diameter, shoes and backing plates for starters. They are are larger in diameter then the A stuff.
I know the voices aren't real but damn they have some good ideas! |
02-01-2018, 12:01 AM | #4 |
Re: Brake shoes
Also, the A drum is steel, and the hydraulic drum is cast iron.
02-01-2018, 12:51 PM | #5 |
Re: Brake shoes
In mid 31 Ford went to cast iron drums The original spoked cast iron front drums were made as one piece with the hubs . The original cast rear drums mostly looked like the new cast rear drums . The original Cast drums were what we use to call cast steel, they would usually bend rather than crack like some of the cast iron drums sold now . I've never cracked or bent any of them . The new cast iron drums are fine for me , if I was buying new .
02-02-2018, 12:35 PM | #6 |
Re: Brake shoes
Hydraulic brakes are just reverse, the shoes in the front are larger and the fronts are 60 percent and the rears are 40 percent. If you are re-doing your brakes I would suggest you use cast iron drum for mechanical or hydraulic. Ron |
02-02-2018, 12:45 PM | #7 |
Re: Brake shoes
I'm using 1942 hyd . yes the drum is larger & my brake shoes are only for 1942
V4f |
