09-04-2010, 01:54 PM | #41 |
Re: How's your cam ??
i'm running an L-100 in my 258 flat motor, Brockman steel packs for mufflers, even makes the Chevy guys take notice when idleing bye, plus it pulls like crazy in 2 nd gear.
09-07-2010, 02:38 PM | #42 |
I got the specs off of my cam sheet from Crower, Mark told me way back when that it was a great cam for mid to high performance. I think they must have used it on some of their larger cube engines?
09-07-2010, 02:40 PM | #43 |
Tom - Did Crower make all of MCF's cams? The measurements I pulled off mine don't match the printed specs in the article either. Crower does not even list anything for the flathead either.
09-07-2010, 03:21 PM | #44 |
I still have an old MCF catalog at home, will check it out after work tonight. I remember when Mark sent me the cam, and springs that the crower was in a box with their name and part number. I did not save the box, but my friend who helped me with the install suggested keeping the cam spec sheet. Will look tonight to see what it reads. I know Mark is working with shadow rods here in Michigan on the french flatheads but have not heard much new lately. His new site is www.motorcityspeedequipment.com
09-07-2010, 06:14 PM | #45 |
Bill Stipe here in Wisconsin used to grind cams for MCF. Don't know if he did them all or for how long.
09-07-2010, 06:24 PM | #46 |
09-07-2010, 08:19 PM | #47 |
If you go to the motorcityspeedequipment site I think there might be a way to contact Mark. Always was very helpful to me and when I met him he was very down to earth. His heat attack almost killed him, and he said sometimes he wished it had. Lost just about everything after all of the expense of the hospital care. Hey, I found my Crower timing tag, it reads: part number E-33794, grind number SPL 59 A Early 262 duration on intake and exhaust and .383 lift with 112 lobe separation. Good luck in finding Mark, I am sure he will have some good information for you.
09-07-2010, 10:14 PM | #48 |
I assume you are asking about Bill Stipe. If you go to the discussion about camming and gearing, he had a post there. Goes by 29 Red Rocket. You could PM him.
09-13-2010, 04:48 PM | #49 | |
Thanks for the lead flatjack9 - I will PM him. I sent an email to Mark via Phil Goller. We'll see if I get a response. Thanks all for you help and sorry for hi-jacking the thread. |
09-22-2010, 05:08 PM | #50 |
Does anyone have any audio clips of the 1007b? I'm interested in hearing 1.
Thanks Matt |
10-10-2010, 06:00 PM | #51 |
46FATS; Did anyone get back to you ( off line ) about hearing the 1007-B cam run ?? Its the cam I am putting in my 4" stroker, BUT, its at least a year from making any noise..??.. OLD....BILL .. at .. [email protected]
01-03-2011, 10:40 PM | #52 |
Still interested in hearing a Isky 1007b.
thanks Matt |
11-11-2011, 10:57 AM | #53 |
Anyone willing to compare these three ? I'm looking for something hot and fun to drive, cool sounds also, but as streetable as possible. Will be driven often but not daily.
I came down to these two. Could someone compare them ? How many mods do they require ? isky 1007B literio L100 PS: I thought I was in the HAMB, I'm mercjoe. I've registered yesterday to the Barn so please, consider this my introduction ;-| |
11-11-2011, 01:09 PM | #54 |
Welcome. I have a Winfield SU1-A in my engine. I like it a lot. Similar to the L100. At an Auburn meet I was able to have a side by side idle comparison with an L-100. Sounded the same.
11-11-2011, 02:58 PM | #55 |
I think the 1007B and the L-100 would work very well in tour engine sounding similar. I never ran the L-100 in a stock car but several of my friends did and they were c avery good running cam. I have one in KGS engine, sounded pretty good on the Dyno.
11-11-2011, 04:51 PM | #56 |
Thanks Ron, so both cams should do a good job wihout major mods ? I mean multi carbs, headers or heads ?
11-11-2011, 04:51 PM | #57 |
11-11-2011, 05:09 PM | #58 |
mercjoe; .. Welcome, from all of us, I am very proud of this post " HOW'S YOUR CAM?" and glad someone brought it up again, lots of good information and input here, do go back and read all. Now some questions for you,JOE, what is your engine, bore, stroke, your car/piceeeeup and gearing ??? (tooth count) and tire size,(rear) .... And to your questions, both cams are GOOD TO GO with, " carbs " no more than two. heads, any of the after market are good for your street car/pickup.. or mill your stock heads .050, to start with ..headers, yes, go with a smooth tube (not Fetons)..We all know, to make our flathead run good and sound good too...It must breath, thus a good cam with good lift. and exhaust system, all the way out the back. some will say go stright pipe, others muff, personally I MUFF. and keep piece in the hood... Ignition/distributors... don't get carried away with after market dist. the stock divenbell is ...a..a..a...s.. ok... the crab is better.. and good to work with. it will keep-up with any cam on the steet...and can be run 6v or 12V.,? thanks all of you, for all your input, and I must make a correction,,, ( daily driver) no.no its a frequently/occasally drivere...and a stock cam ..no. Ol'Ron... all this time, money, grinding,balincing,line boring, port.polish and some chrome too. a stock CAM come on Ol'Ron ..... THANKS ALL ....OLD....BILL
11-11-2011, 06:36 PM | #59 |
11-11-2011, 07:24 PM | #60 |
I can give feedback on a few cams, one in my 33,std bore 21 stud engine,has the stock cam,it is one nice motor and a pleasure to drive,
The other 33 eng has .060 overbore,and a late model 8ba cam I modified to fit the 21 stud eng,again great to drive, Our front engined dragster has a new Crower roller cam,my boy spoke to Dave Crower and he made it special for us, this has pushed our dragster to its PB the other month at 9.40 @ 140 mph If I could work out how to post pics I could show our dragster,But its in my album, Lawrie |
