10-16-2019, 01:07 AM | #1 |
Radiator
Suffering from brain failure again. I just purchased a 1931 Victoria and it has been idle for over 40 years. The radiator has rust colored coolant when I drained it. Any suggestion on my next step?
10-16-2019, 03:45 AM | #2 |
Re: Radiator
Step one : fill with water see if it leaks. step 2 if no leaks do a search on this forum for cleaning radiator
10-16-2019, 11:24 AM | #3 |
Re: Radiator
I have used Simple Green in the cooling system and ran it for a short period of time. I then back flushed it with clean water with good results.
10-16-2019, 12:59 PM | #4 |
Re: Radiator
WELCOME Depending on where you are, it's starting to get COLD. Make sure you've got all the water out of the rad and block.
Paul in CT Many ways to clean: Simple green, vinegar, EvapoRust, CLR, etc There's a search function above and this subject has been covered multiple times, |
10-16-2019, 01:17 PM | #5 |
Re: Radiator
Charlie Stephens |
