Old 11-12-2019, 02:20 PM   #1
Joe Immler
Default 1941 Ford LED tail lights
Some time ago I wrote that people said they could not see my tail lights or turn signals in the daylight hours.It is a restored 6 volt positive ground system. Some suggested I check with Ken Check. I did. I sent him the lights and he converted them to LED and also sent a flasher for the turn signal upgrade.
WOW ! What a difference! Ken was very helpful and informative about what he would do and he was in good contact with me.
I very highly recommend him for this work!.
Ken Check [email protected]
Joe Immler is offline   Reply With Quote
Old 11-13-2019, 08:17 AM   #2
corvette8n
corvette8n's Avatar
Default Re: 1941 Ford LED tail lights
Does he have a website also?
Old 11-13-2019, 09:17 AM   #3
Joe Immler
[email protected] This has a few sites to read.
Old 11-13-2019, 10:54 PM   #4
fordor41
fordor41's Avatar
United Pacific sells LED tail light lens for '41 Fords but I believe only 12V. Are super bright
fordor41 is offline   Reply With Quote
Old 11-18-2019, 04:05 PM   #5
grumppyoldman
grumppyoldman's Avatar
I have the LED bulbs in my 41 and all I had to do was install the bulbs. They are bright and my flashers are bright. I think they came from a site called Brite Lite, not sure of the name but easy install. Al
grumppyoldman is offline   Reply With Quote
Old 11-18-2019, 04:18 PM   #6
4t7heaven
Another good reason to convert from 6V to 12V. Bright lights are great. You can see so much better and other drivers can see you much better. The conversion also allows you to install electric wipers, another safety issue.
4t7heaven is offline   Reply With Quote
Old 11-21-2019, 06:53 AM   #7
fortyonerag
fortyonerag's Avatar
Deleted post
fortyonerag is offline   Reply With Quote
Old 11-21-2019, 09:05 AM   #8
Merc Cruzer
Merc Cruzer's Avatar
You will find then here:
https://www.ledlight.com/6-volt-posi...ed-lights.aspx
Merc Cruzer is offline   Reply With Quote
