06-02-2010, 03:49 PM | #1 |
Fire wall insulator
Does anyone have any experience on these insulators? Do they help with noise and heat and are they a bear to install?
06-02-2010, 03:54 PM | #2 |
Re: Fire wall insulator
there was a discussion on these about a week ago here
Paul in CT |
06-02-2010, 04:06 PM | #3 |
they help with noise and heat and they also look decent. i find it very easy to put in but youll hear otherwise also. (cutting them in half etc.) i put one in a 30 tudor and slid right up
06-02-2010, 04:22 PM | #4 |
We reviewed these in the Model A Times several years ago. They work very well and are well made. Installation requires removal of everything that passes through the firewall, wiring fuel lines etc. You use the junction box screws to secure it. It is not difficult to install. We followed up with installing them in all of the Model A Times project cars, that is how much we think they work.
06-02-2010, 04:30 PM | #5 |
I used a roll of the shiny stuff. Cut around the lines, etc. It is stiff enough to stay in place. It cut the noise in half as well as the heat. I also have a heat deflector over the muffler.
06-02-2010, 06:38 PM | #6 |
Thom IV |
06-02-2010, 08:10 PM | #7 | |
06-02-2010, 08:43 PM | #8 |
Anybody have a picture of one of these installed?
Thanks |
06-02-2010, 10:00 PM | #9 | |
First... I've never laid eyes on one of the rigid firewall insulators. Second... Originally, one could purchase after-market felt pads for under the floor mats of 'A's. (check out the "Unauthorized Accessories" book.) Third.... Starting with 1/2" thick grey felt carpet padding, a set of sharp shears and a box cutter, I made a full set of pads for my Tudor. One piece fits under the rear seat. One piece (under the rubber mat) runs from the rear seat to the front seat hinges. One piece (again, under the rubber mat) runs from the front seat hinges waaaaay up between the gas tank and the firewall. It stays in place by friction alone. I carefully cut slots so that front section can pull out in an instant. I also cut a three-sided flap for the battery cover. My seams do not line up with either the rubber mat edges or the floorboard edges, so as to aid in draft/noise reduction (read on). To finish it off, I used a rattle can of flat black (outside the car!) to color the felt wherever it showed through holes in the black rubber mats AND the section that extends from the from mats up the firewall. The "firewall" section of the pad now disappears in the shadows. Results? Drafts eliminated. "Light" around pedals eliminated. All pedals (including starter) function fine (caveat... make sure your brake and clutch pedals are restored to spec if you want a draft/light-free seal). Temperature insulation... impressive. Noise reduction... particularly impressive. My wife and I often remark how easy it is to carry on a conversation... even between the front and rear passengers, and that includes running at 50 MPH. Cost? Okay... this may be ten years out of date.... maybe $15.00 Try it. Hope this helps. |
06-14-2010, 04:48 AM | #10 |
I did the same as John with carpet padding.....worked great.
