03-31-2020, 01:32 PM | #1 |
Who lightens flywheels? Looking for a shop
It's a 8ba flywheel I want lightening up.
03-31-2020, 02:06 PM | #2 |
Re: Who lightens flywheels? Looking for a shop
You would have to remove a large amount of material to realize any change in performance. Your best bet is to check with a performance vendor, such as Jegs, for a light flywheel. We resurface flywheels in our shop, and rebalance them, even if the cut was slight. Finding any performance parts for flathead has become difficult, and torque converters have largely replace flywheels with flex plates.
03-31-2020, 03:16 PM | #3 |
Anybody good with a lathe should be able to do that.
03-31-2020, 03:34 PM | #4 | |
What I'm reading I should be able to shave 9-10lbs.Is that right? Fidanza makes an aluminum with an insert weights 15lbs for around $400.00 Maybe I should go that way since it includes a new ring gear. |
03-31-2020, 03:59 PM | #5 |
only use an aluminum lightweight flywheel in a light car, or you may end up having to rev up the eng, and possibly slip the clutch to get rolling. the heavy flywheel prevents this by way of centrifugal force of the rotation of the flywheel/crank assembly. the light flywheels work in early cars like model A's 32-33's especially when robbed of their "extra" parts like fenders, hoods, etc. I think 8-10 lbs off an 8BA wheel is doable, but should be done by someone who has knowledgeable about how and where to remove the material
03-31-2020, 04:22 PM | #6 |
Short URL: http://smu.gs/14g7eDW |
03-31-2020, 04:27 PM | #7 |
Ive done them. Used a ford industrial 4 cyl in a model A and they have a massive flywheel. Cut 13 lbs off it. Just takes awhile.
When i did one for a early flathead, cut the end off a junk crankshaft to hold it in the lathe. Taper all the cuts |
03-31-2020, 04:41 PM | #8 |
i've done them too. in my 14" clausing they only fit with the ring gear off. i've taken the big blob off of several of the early 9" clutch's. use a bit for cast iron and run slow. it takes several beers and makes a helluva mess, but i get a good finish
03-31-2020, 09:39 PM | #9 |
At a place I worked many moons ago, we had a dedicated lathe for lightening flywheels. We did a lot of them. We always balanced them afterward. We never had any problems with any of them, EXCEPT ONE in a 32 roadster. I just happened to be the passenger and the driver was going to show me how he could full power shift (button shift) with his new light flywheel. He missed the one two shift, the engine went over 7K free winding and the flywheel exploded. It was a toss-up whether the car or the people got the worst of it.
They quit lightening flywheels. Too many possible harsh side effects. |
04-01-2020, 12:37 AM | #10 |
And getting mass to the center of flywheel does the same job...so hopefully there isnīt an 11" clutch on the flywheel you work with.
Just going from a 11" to a 9" does quite a bit to rotational mass. |
04-01-2020, 07:43 AM | #11 | |
04-01-2020, 07:44 AM | #12 | |
04-01-2020, 07:51 AM | #13 | |
Good advice for a high hp car. Sounds like a little more then my 239Cu. in. I'm not too concerned. |
04-01-2020, 07:53 AM | #14 | |
There's a 10 incher now, but that can change. Is 9 inch too small? |
04-01-2020, 08:06 AM | #15 | |
I went with a 10" clutch on a aluminum flywheel (Weber with Centerforcce PP & clutch) to split the difference |
04-01-2020, 10:08 AM | #16 |
Exploding flywheel: Pete's story is one to pay attention too . . . I just don't like the potential of a cast iron flywheel to potentially grenade. (I'm not going to risk my feet to find out).
I'm currently having a special steel billet one made at RAM clutches (lightened and profile cut from their standard 33 lb version) - should come in about 24 - 26 lbs. I'm taking out the Fidanza aluminum one that I have in my 32 at the moment - just too light of a flywheel for normal street driving . . . have to slip the clutch a lot as it doesn't have enough reciprocating weight to make normal standing starts as easy/smooth as I'd like them. I'll report back how I like the new one (once this dang shutdown of the world is over!). |
04-01-2020, 10:15 AM | #17 |
Scatter sheild. One of the old hotrods i have, the removable toeboard is fabricated out of 4 pieces of 1/4" plate.
Who really beats on these cars that hard anymore? |
04-01-2020, 10:45 AM | #18 | |
04-01-2020, 11:38 AM | #19 | |
04-01-2020, 03:33 PM | #20 |
