Old 11-07-2018, 03:34 PM   #1
qmdv
qmdv's Avatar
Default Highboy headlight and shock brackets
I am working on a 32 Highboy Roadster. I am trying to figure out the best way to mount tube shocks and how to mount head lights. I have a set of F-1 upper shock mounts that I salvaged from behind a neighbors barn. I also have a bent up model A headlight bar. Does anybody have any pics of how they could be married together
qmdv is offline   Reply With Quote
Old 11-07-2018, 03:46 PM   #2
woodiejon
Default Re: Highboy headlight and shock brackets
So cal speed shop sells just what you want.
woodiejon is offline   Reply With Quote
Old 11-07-2018, 04:11 PM   #3
RalphM
RalphM's Avatar
Not a great angle, but maybe you can see. I used a bent up model A light bar, and a set of F-1 shock mounts. The headlight cups are welded to the upright on the shock mount. I cut it off about 4 to 5 inches from the cup. I also cut and turned the bottom mounting then rewlded dfor the shock mount to align with the two holes for the front crossmember rivets.
File Type: jpg 8763F37F-C16B-4AAD-AC7A-DC085DE4A1CF.jpg (80.5 KB, 90 views)
RalphM is offline   Reply With Quote
Old 11-07-2018, 05:00 PM   #4
qmdv
qmdv's Avatar
I saw that but I am not a stainless fan. I guess I could paint it. Half the fun is building it myself though.
Old 11-07-2018, 05:03 PM   #5
qmdv
qmdv's Avatar
Good idea.
Old 11-07-2018, 05:04 PM   #6
RalphM
RalphM's Avatar
I feel the same way, I’ll try and get a pic of the back side for you tonight.
Old 11-07-2018, 05:36 PM   #7
john in illinois
john in illinois's Avatar
Mine are similar to Ralphs but mine is an A frame . F1 in rivet holes and ends of model A bar welded on.
I made a jig to weld them the same.
John
File Type: jpg 1041734C-2F9B-492C-A356-03FE118B4963.jpg (67.0 KB, 75 views)
john in illinois is offline   Reply With Quote
Old 11-07-2018, 07:05 PM   #8
qmdv
qmdv's Avatar
Ralph M, what is the ride height of those shocks. And is your lower shock arm welded to the axle. I have some lower shock mounts that mount to the underside of the front wishbone. I end up with a ride height of 15 inches unless I shorten the F-1 upper mounts
Old 11-07-2018, 10:13 PM   #9
Andy
I made some cups for the lights and some brackets that attach them to the shock mounts. I did not end up using them so they are available. I will try to list them tomorrow in the classifieds.
Andy is offline   Reply With Quote
Old 11-07-2018, 11:08 PM   #10
RalphM
RalphM's Avatar
Shock ride height is 11-1/2 inches. I made my own custom lower mount that is a bung welded to where the spring perch used to be on the 37 to 41 front wishbone. These were the shortest Shocks I could find with the chrome covers that I wanted.
File Type: jpg 339E2AB4-F2C8-422C-8F6E-E9C1EF1D9BE6.jpg (39.7 KB, 39 views)
File Type: jpg 2FD488E3-6921-4F07-9210-473329D342FD.jpg (28.5 KB, 29 views)
Old 11-07-2018, 11:47 PM   #11
qmdv
qmdv's Avatar
Thanks so much for those pics. Next time I am North Pole I will buy you one. I take it you drilled out rivet holes to 7/16
Old 11-08-2018, 12:47 AM   #12
RalphM
RalphM's Avatar
Yes, take care to align the crossmember, so drilling them out bigger doesn’t cut though the bottom edge of the crossmember.
Old 11-09-2018, 02:10 PM   #13
Andy
This is whay I made.
Old 11-09-2018, 03:44 PM   #14
RalphM
RalphM's Avatar
Sweet and simple Andy, do those bolt to the upper shock mount?
Old 11-09-2018, 05:07 PM   #15
Andy
Yep, They replace the washer on the shock mount next to the shock bushing.
