05-17-2019, 06:00 AM | #1 |
need piston
hello everyone
I did a stupid thing, im 67 and ought to know better, i dropped a small screw into my spark plug hole in my 1948 flathead pick up engine. then i started it, big mistake. I need a piston, some rings and a valve. It has an H stamped onto the head, can anyone help me. thank you it is a 6 cyl Last edited by mike dixon; 05-21-2019 at 05:53 AM. Reason: add text |
05-17-2019, 06:07 AM | #2 |
Re: need piston
6 cylinder H engine ?
You need to check for what oversize you have if not STD to... |
05-17-2019, 06:09 AM | #3 |
Re: need piston
Are you sure there is not cylinder wall damage? If you are going to replace a piston, at a minimum the clyinder would need to be honed I would think.
05-17-2019, 07:15 AM | #4 |
Re: need piston
I have some used H parts if it’s a 6 cylinder
05-17-2019, 07:47 AM | #5 |
Re: need piston
I also have some NOS six cyl pistons and rings if you can determine the size you need.
05-21-2019, 05:51 AM | #6 |
Re: need piston
05-21-2019, 05:51 AM | #7 |
Re: need piston
6 cyl i need a piston, can you call me 618-401-5977 thank you so much
05-22-2019, 06:36 AM | #8 |
Re: need piston
the piston is .040 still need it and rings and a valve
05-22-2019, 06:39 AM | #9 |
Re: need piston
.040
05-22-2019, 07:03 PM | #10 |
Re: need piston
Let me look in my parts stash.
05-22-2019, 08:01 PM | #11 |
Re: need piston
Pm sent
