09-25-2015, 12:34 AM | #1 |
front shackle bushngs
Over the years I have rebuilt a number of Model A front ends and I have noticed a difference in front shackle bushing outside diameter requirement in both the spring and the perch. Some use a thin-wall bushings, some use a bushing that is thicker in outside diameter.
Most front shackle sets come with thin wall bushings. If you order front shackle bushings from Bratton's they are thin-wall. In order to accommodate those springs and perches that I have encountered that require the thicker outside diameter bushing, I ordered a quantity of rear shackle bushings from Bratton's and had the length cut down. The front perch and spring that require a thicker outside diameter bushing are the same as the rear shackle bushing, only shorter. Does anyone know why there is a difference? Has it to do with the year of manufacture, or the particular suppliers Ford was using. Tom Endy |
09-25-2015, 12:46 AM | #2 |
Re: front shackle bushngs
I would think it was due to different suppliers
09-25-2015, 12:44 PM | #3 |
