09-24-2015, 06:54 PM | #21 | |
Re: Battery
My caps were moulded for vents, but there were membranes, blocking the holes. When charging batteries, they are safer from explosion or fire, with the CAPS REMOVED!!! It's the PRESSURIZED GASSES THAT ARE DANGEROUS I speak from experience, family friends have run a Battery Rebuilding/Sales shop, since the '50's & I'm knowledgeable of ALL the steps in rebuilding batteries. Bill W.
09-24-2015, 07:02 PM | #22 | |
Re: Battery
i never did it tho.... |
09-24-2015, 07:35 PM | #23 |
Re: Battery
A little more background. My car has a battery disconnect which is always open when i turn off the engine.
I took a paper towel soaked in backing soda water and with the caps installed wiped down the whole battery.. As I said, I believe my charging likely made my battery worse... time will tell...
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio Last edited by mshmodela; 09-26-2015 at 05:59 PM. |
09-24-2015, 08:20 PM | #24 |
Re: Battery
One more thing I learned the hard way. If you have any battery acid touch your clothing, no matter how quickly you rinse it off.........it's too late.
Lost a brand new pair of blue jeans when I was in the 10 grade. |
09-24-2015, 08:48 PM | #25 |
Re: Battery
For those who want to know more, this is a pretty good primer on how lead acid batteries work:
http://evbatterymonitoring.com/webhelp/battery_book.htm John
Houston, Tranquility base here. The Eagle has landed. |
09-26-2015, 12:37 AM | #26 | |
Re: Battery
More seriously, when handling batteries be very careful not to short them between terminals with clumsy wrench usage. Even with the high internal resistance of a lead acid battery, there can be enough current flow to cause serious injury. I have witnessed a one inch thick pry bar melt like a fuse when dropped across a battery pack in an electric powered fork lift truck. and remember ALWAYS DISCONNECT THE GROUND FIRST. |
09-26-2015, 05:37 PM | #27 | |
Re: Battery
09-26-2015, 05:55 PM | #28 |
Re: Battery
The two multistage chargers I have can only be turned on once connected to the battery terminals.
Should stop any sparks. |
09-26-2015, 06:56 PM | #29 |
Re: Battery
I have two Sears 6 amp 6/12 volt chargers. The early one from the 60's is great because it can charge any battery, but the newer one from the 90's won't kick on unless the battery has enough charge to turn on the circuit you just mentioned. As you mentioned, I guess it might be a safety thing.
