Old 09-20-2015, 04:54 PM   #21
burner31
burner31's Avatar
Default Re: Look what followed me home today
Originally Posted by Jim Mason View Post
1 year ago today...
What does it look like today?
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 09-20-2015, 06:25 PM   #22
Jim Mason
Jim Mason's Avatar
Between winter, health, and life getting in the way....hasn't changed a bit.
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 09-20-2015, 06:34 PM   #23
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Good luck its great!
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 09-20-2015, 06:41 PM   #24
Benson
Benson's Avatar
Originally Posted by TinCup View Post
Wow that has to be the best color combination I have ever seen. Wait that isn't my car. Good Luck with it.
I knew that it was not your car because the lights are not blinking
Benson is offline   Reply With Quote
Old 09-20-2015, 09:10 PM   #25
burner31
burner31's Avatar
Benson, on your avatar, is that a "crate" motor?
Keith
Shawnee OK
'31 SW 160-B
Old 09-21-2015, 10:42 AM   #26
CarlG
CarlG's Avatar
And "low rider" tires
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-21-2015, 12:39 PM   #27
Benson
Benson's Avatar
Yes Crate Motor I was going to post it on HAMB but figured I would be "put up a cross" as they sometimes have a different sense of humor!
The tires on this car are also WIDE WHITE WALLS... It is hard to see them as the sidewalls are so low profile!
Old 09-21-2015, 08:56 PM   #28
wgmatt
wgmatt's Avatar
Great looking ride. Did Mama say you could keep it?
wgmatt is offline   Reply With Quote
Old 09-22-2015, 11:41 AM   #29
BAL1962
BAL1962's Avatar
I checked the camshaft and it looks ok. The roll pin was sheered on the oil pump drive housing. I took apart and freed up the dist. today. The gear is worn on the drive but it rotates with the cam. I will put it back together and hope for the best. I did check compression and #1 has none the rest are low. I just want to hear it run for now. I'll let you all know more when I know more!
BAL1962 is offline   Reply With Quote
Old 09-24-2015, 09:02 PM   #30
BAL1962
BAL1962's Avatar
I got the engine running. The oil pump drive gear is worn enough that at times will skip a tooth. The cam gear doesn't seem to have any wear.
I just wanted to hear it run for now. It started so fast it amazed me! That's all for now!
Old 09-25-2015, 09:06 AM   #31
burner31
burner31's Avatar
Good Job.
I know hearing it fire and run for the first time put a smile on your face that could not be wiped off with a wood file.
Keith
Shawnee OK
'31 SW 160-B
