08-08-2018, 07:22 AM | #1 |
Gas leak
Going to change all gas lines and settlement bowl today. Any hint as to what to use as a fitting sealant Most are compression type but a few threaded Tnx RAY
08-08-2018, 11:12 AM | #2 |
Re: Gas leak
Compression fittings do not require any sealant, just lube the threads a little for easier turning of the nut.
08-08-2018, 10:39 PM | #3 |
Re: Gas leak
What do you mean by threaded? Like a pipe thread? Or like a flare fitting, which doesn’t need anything but oil.
08-08-2018, 11:33 PM | #4 |
Re: Gas leak
08-09-2018, 10:35 AM | #5 |
Re: Gas leak
The main gas valve coming out of the gas tank is the only threaded fitting I can think of. It has a ¼" pipe thread. I used "Yellow" pipe tape.
08-17-2018, 10:19 PM | #6 |
Re: Gas leak
08-18-2018, 08:31 AM | #7 |
Re: Gas leak
I use Aviation-Permatex thinned with a little denatured alcohol. On all my "A" gaskets including threads.
Bob-A |
09-15-2018, 11:21 PM | #8 |
Re: Gas leak
I had a car that had a hole in the bottom of the gas tank from being hit with a rock We were miles from anyone and it was leaking fast .I had a tube of Seal All ,so I grabbed a cleanex soaked it with the glue ,held it for a few minutes and it stopped leaking .We drove the car for a few years and I never touched the tank again .we allways carried a tube in the trucks for radiater leaks .
