Old 12-15-2019, 02:36 PM   #1
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Bubba distributor skips a beat ????
I am glad we dont get very many returns or problems , but when we do it drives me nuts. Two customers have had a problem in the last few months with our late model chevrolet conversion. In all we have shipped over 2500 of these units with little or very few issues. (and when a issue occurs we fix it on all our units from that point on) I dont have a list but we have isolated and fixed many design changes over the years.
This unit skips a cylinder or two . Starts great but skips when you rev it up. I did all i could do for the customer thru emails etc . Finally i said lets pick it up and look it over here at the shop.
The grandson opened it up today and said i dont think this is right (he has put a few of these together ). Holey shit..looks like the condensor wire has been hitting the rotor screw ????? A bend in the wire and it wont do that again..repaired with some nail polish...........ya just never know....
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 12-15-2019, 02:41 PM   #2
The Master Cylinder
The Master Cylinder's Avatar
Default Re: Bubba distributor skips a beat ????
Good catch for the Grandson. You can see the debris from the screw hitting the wire.
Maybe shorten the rotor screw so it doesn't poke out so far too...
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 12-15-2019, 03:03 PM   #3
RalphM
RalphM's Avatar
Good catch by your grandson! It doesn’t take much to cause an ignition hiccup.
RalphM is offline   Reply With Quote
Old 12-15-2019, 03:10 PM   #4
leon bee
Looks like the customer coulda seen that.
leon bee is online now   Reply With Quote
Old 12-16-2019, 08:40 AM   #5
slowforty
slowforty's Avatar
Only if you know what you are looking at. Seems to be my problem, most of the time now.
slowforty is offline   Reply With Quote
Old 12-16-2019, 12:06 PM   #6
deuce_roadster
deuce_roadster's Avatar
I would also have changed to shorter screws or put another washer under the head so there would be no protrusion.
Old 12-16-2019, 04:19 PM   #7
leon bee
Was it your car? If so I retract my rude comment.
Old 12-16-2019, 05:37 PM   #8
slowforty
slowforty's Avatar
No,well But i take Constructive Criticism well. If you believe that I have some items for sale.
Old 12-16-2019, 07:56 PM   #9
leon bee
Personally, I usually find things like that. However it is almost always through sheer desperation.
Old 12-16-2019, 08:07 PM   #10
PeteVS
PeteVS's Avatar
I had that happen once on my C**** that was originally equipped with a distributor of that nature. I was told that the condenser wire should go UNDER the looped ground wire. (Somebody else had done me a favor and put in a new set of points and ran the condenser wire up over the ground wire.)
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 12-20-2019, 06:43 PM   #11
PeteVS
PeteVS's Avatar
I was wrong with my post above. The condenser lead doesn't go under the ground lead, it goes under the primary lead per the shop manual. This is to prevent exactly what happened here.
Old 12-22-2019, 12:48 PM   #12
BUBBAS IGNITION
Yep great picture ...........its in my file from now on...
[email protected]
Old 12-23-2019, 07:24 AM   #13
Frank Miller
Frank Miller's Avatar
In all fairness the wire may have been tucked up further when the customer installed the cap. The cap needs to be off to install the distributor. An honest mistake and as stated above routing it differently would have averted this problem.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
