09-09-2016, 09:08 PM | #1 |
Installing fog lights
I'm installing some fog lights on my 46 truck. It is the stock 6v positive ground electrics. I would like to power these lights via a relay. My question is would the Bosch 6v relay work for this application and would I need just one or would I need two ( one for each light). Anyone have a wiring diagram? Thanks for any input.
09-09-2016, 09:13 PM | #2 |
Re: Installing fog lights
You need one and yes on the diagram.
I updated my original post, I was thinking high/low beams. I would use the diagram for a fuel pump I have attached, the wire to the pump would be the fog lights and would Y to go to both pumps. I will also attach a headlight diagram if that helps any, you would only use one of the relays and a switch would replace the dimmer. Last edited by JSeery; 09-09-2016 at 09:35 PM. |
09-09-2016, 09:22 PM | #3 |
09-09-2016, 09:29 PM | #4 | |
How are you wanting to control them, dedicated toggle switch or the existing lighting control? Are you wanting to use original style wiring or modern wiring? Last edited by JSeery; 09-09-2016 at 09:42 PM. |
09-09-2016, 09:53 PM | #5 | |
09-09-2016, 09:54 PM | #6 |
09-09-2016, 11:09 PM | #7 |
Good luck on your installation. Please dont drop any of your bulbs. I have been looking for some for awhile and the ones i found are extremely expensive.
09-09-2016, 11:39 PM | #8 |
2x JSeery ..... My '47 uses a single relay in the engine compartment. Power for the fog lights themselves comes from the battery thru a 20 amp in-line fuse near the relay in the engine compartment. Power to operate the relay (small amperage draw) comes from my ignition switch thru a toggle switch under edge of dash with LED in its knob to let me know when its turned on - good for us old-folk.
I use 12 volts and a 20 amp rated relay. Since your operating at 6 volts I'd recommend a 30 amp relay (same cost; maybe same relay pending manufacturer). |
09-10-2016, 07:00 AM | #9 | |
09-10-2016, 08:26 AM | #10 |
Not a good idea! 6v will sometimes latch a 12v relay, but you are right on the lower edge of the latching rating and they are not dependable. Much better to just start with a 6v relay in the first place.
09-10-2016, 09:31 AM | #11 |
Ok, check these over and see if it is clear (and error free )
09-10-2016, 10:12 AM | #12 |
