09-07-2021, 10:52 AM | #1 |
ford 47 pickup starter alignment problem
how to adjust alignment with shims 59 AB ENGINE.
JIM |
09-07-2021, 11:17 AM | #2 |
Re: ford 47 pickup starter alignment problem
there are no shims,make sure you have the small bracket that bolts to one of the starter bolts to the oil pan, make sure you have a 59AB flywheel and not an 8BA flywheel
09-07-2021, 11:24 AM | #3 |
i am not familiar with the bracket you reference. it is an 11 inch flywheel.
jim |
09-07-2021, 11:54 AM | #4 | |
What alignment issues are you having? A flathead doesn't use shims like a SBC would. They shouldn't be required. |
09-07-2021, 12:03 PM | #5 |
It is an "L"-shaped bracket about 1 1/2" long on one side and about 1" on the other and about 1/2" wide. One end bolts under the head of one of the long starter mounting bolts and the other under an oil pan bolt. Back in the day, a lot of them were left out when work was done on the starter. I think I may have a spare or two if you have trouble finding one.
09-07-2021, 01:28 PM | #6 |
Jim Last edited by jimtims; 09-07-2021 at 01:32 PM. Reason: misspelling |
09-07-2021, 02:31 PM | #7 |
pictures????
09-07-2021, 03:12 PM | #8 |
This is the bracket that "tubman" speaks of. You can see the difference in flywheels below. The six pressure plate bolt holes are NOT drilled all the way through on the '48 and earlier (59A) wheels. The spacing difference is obvious. DD . |
09-07-2021, 07:55 PM | #9 | |
09-09-2021, 09:43 AM | #10 |
Thank you all for your replies. when I figure out how to post a picture on this site, I will.
Jim |
09-09-2021, 09:45 AM | #11 |
i have one on order. hoping it will cure my alignment issues.
Jim |
09-09-2021, 09:47 AM | #12 |
I have pictures and will try to post them,
Jim |
09-09-2021, 10:51 AM | #13 |
09-09-2021, 12:53 PM | #14 |
Here are Jim's photos:
09-15-2021, 06:16 PM | #15 |
Thank you for the tip on the small bracket. My truck did not have the bracket when I got it 6 years ago. I have gone thru 3 starters in the time I have had the truck and I put a new starter in today and sure enough it fixed my problem. Starts are quiet and works every time.
Life is good! In your debt, Jim |
09-15-2021, 07:59 PM | #16 |
Great news!
11-26-2023, 04:12 PM | #17 |
turned out the real problem was the oil pan and mount for the starter. now my problem is installing new one piece oil pan and getting there rear seal in correctly to stop leak.
