06-11-2018, 03:59 PM | #1 |
46 horn wiring
Getting too old to remember all this stuff...…….Question,
I am trying to install a 12 volt horn on a 12 volt 46 pickup. On my 46 fordor the wire coming up thru the shaft to the horn ring is hot. So what happens when the horn is depressed? It seems it would create a short circuit. This pickup has the same single wire up to the button. The newer horn I have has a terminal and uses the mounting bracket for ground. How can I make it work. Thanks John |
06-11-2018, 04:10 PM | #2 |
Re: 46 horn wiring
The wire in the column should ground the horn relay.
06-11-2018, 04:22 PM | #3 |
Re: 46 horn wiring
I wired my horn through a relay, my horn wire provides battery negative to fire the relay. The 12v relay is around $6 at the big box auto part stores.
Greg |
06-11-2018, 05:14 PM | #4 |
Re: 46 horn wiring
Good point, are you using a horn relay? As has been pointed out already, the wire up the column should be a ground wire to the relay. There are three connections on a horn relay, battery power, ground wire to the horn button (the wire up the column) and a wire to the horn(s).
06-11-2018, 06:55 PM | #5 | |
Re: 46 horn wiring
So it looks like I can get a relay and use this later horn and Jseery's diagram. I will be off to CARQUEST in the morning. Do I need specs on the relay? CharlieNY rebuilt the pump and carb after it sat for 4 years with old gas in it. Great craftsman Thanks again John This is the pickup I am working on. Belongs to a friend who is now in a nursing home but his wife wants to keep it in working order. Last edited by oldford2; 06-11-2018 at 07:12 PM. |
06-11-2018, 08:32 PM | #6 |
Re: 46 horn wiring
Greg Last edited by Greg58; 06-11-2018 at 08:48 PM. |
06-11-2018, 09:32 PM | #7 |
Re: 46 horn wiring
I would use a regular horn relay, but up to you.
06-12-2018, 04:29 PM | #8 |
Re: 46 horn wiring
Got a new horn relay and wired per Jseery diagram. Still not working. Tested the newer horn and it works. I could always buy a "horn button" and it would work but trying to keep things original.
John |
06-12-2018, 04:59 PM | #9 |
Re: 46 horn wiring
A couple of things to check, ohm the horn wire with a multimeter, connect one lead to the wire from the horn button and the other to a good ground. With the meter set to ohms the meter should zero out when the button is made. If not check for grease or paint under the button, if the button wire checks good recheck the wiring on the relay or make sure the relay is the right type that needs frame ground to activate it.
Greg |
06-12-2018, 05:04 PM | #10 |
Re: 46 horn wiring
Is the horn you are trying to use a one wire type?
Greg |
06-12-2018, 05:06 PM | #11 |
Re: 46 horn wiring
Yes
06-12-2018, 05:22 PM | #12 |
Re: 46 horn wiring
What is the part number of the relay you installed?
Greg |
06-12-2018, 06:01 PM | #13 |
Re: 46 horn wiring
Napa hr-101
06-12-2018, 06:36 PM | #14 |
Re: 46 horn wiring
I would start by checking at the relay. Jumper the ground terminal on the relay to a good ground. That will tell you if the relay is wired up correctly and working. Next jumper the steering column wire under the steering wheel to a good ground. That will tell you if the ground wire is connected up properly and intact. If both of these check out, then the issue is somewhere in the horn button mechanism itself.
06-12-2018, 07:43 PM | #15 |
Re: 46 horn wiring
According to the Napa web site you should have a B terminal for battery +, a H terminal for horn and a S terminal for the wire to the column.
Greg |
06-13-2018, 09:41 AM | #16 | |
Re: 46 horn wiring
O K ...Got it. I reversed the horn and button wires and it works great. Thanks for all the help. John |
06-13-2018, 01:40 PM | #17 |
Re: 46 horn wiring
Lol.
06-13-2018, 02:13 PM | #18 |
Re: 46 horn wiring
Good
Greg |
