06-17-2019, 08:12 AM | #1 |
Fuel pump stand with small pinholes usable?
My fuel pump stand has some pitting and a few tiny pin holes in the steel tube that goes down into the intake. It was lightly media blasted. The metal is still solid, but will the small holes be a problem? Could it lead to excessive smoke out of the breather? Should I just start looking for another in better shape?
Application is a 221 in a '40. |
06-17-2019, 08:22 AM | #2 |
Re: Fuel pump stand with small pinholes usable?
Fill them with solder to ease your worries.
06-17-2019, 08:47 AM | #3 |
JB weld is an amazing product for filling small holes like that. I've patched gas tanks with it.
https://www.youtube.com/user/roosty6/videos |
06-17-2019, 08:51 AM | #4 |
06-17-2019, 08:56 AM | #5 |
06-17-2019, 09:22 AM | #6 |
Phil Swanson |
06-17-2019, 09:22 AM | #7 |
That's an odd spot to rust since it's usually covered in blowby. I'd just look for a better one, that should be easy enough to come by a better one.
06-17-2019, 09:26 AM | #8 |
I think I saw one on the shelf yesterday that I don't need. If interested, send me the particulars, and if it's the right one, it's yours for shipping. It should fit in a small flat rate box for $7.60 (if you're in the U.S.).
06-17-2019, 09:30 AM | #9 | |
06-17-2019, 10:53 AM | #10 | |
https://picclick.com/Vintage-Ford-Fl...757681644.html |
06-17-2019, 11:04 AM | #11 |
If nobody closer gives you one I have several, you can certainly have one. PM me if need be.
06-17-2019, 05:45 PM | #12 |
I just measured mine and it is about 3" from the base to the top, so it won't work. Sorry. Too bad; it looks NOS. After looking at it, I don'r see why you just couldn't replace the steel tube with a piece of the proper size. It looks like it's just lightly pressed in.
06-17-2019, 08:33 PM | #13 |
I just looked at the picture you supplied and I think maybe mine might be the right one after all. Like I said, it appears to be NOS (or maybe a repop) and the top large sheet metal tube is not installed on mine. Measure the pot metal part of yours and if it's 3", we may have a winner. I don't know how much effort it would take to remove the top large tube from yours, but it might be worth trying.
06-18-2019, 08:29 AM | #14 | |
06-18-2019, 10:01 AM | #15 |
06-18-2019, 10:48 AM | #16 | |
06-18-2019, 04:30 PM | #17 |
Here's what I have. Oh, by the way, after I looked at it, I don't think it will fit in a "Small Flat Rate Box". Better plan on over $10 for shipping.
06-19-2019, 08:11 AM | #18 | |
Thanks |
