01-30-2018, 09:40 AM | #1 |
Heater switch assembly
I am looking for a heater switch assembly for my 46 F1.
My problem is that I don't know what is required. I believe there is a small panel that fits under the dash with two knobs on it. One being the switch that controls the fan speed the other may be a cable but not sure what the cable mounts to or what it controls. If someone can help me with this it would be appreciated. Thank you, |
01-30-2018, 10:43 AM | #2 |
Re: Heater switch assembly
My '47 coupe has the small panel mounted about in center to the underedge of the dash .... it has rounded corners and basically metal color with thin red strips running across it.
Heater motor switch has red markings on it and a small bulb inside it. The switch is on right side of panel - its 5 position: Off at center, clockwise = forward motor rotation to slow and high speed output into floor area. Counter-clockwise from center Off meant primarily for defroster use. Suck air from front thru heater core. Reverse motor rotation for slow and high speed. On the left side of panel (mine anyway) is a choke cable knob with red accent circle in its middle (colors may vary pending year and model, black, red, etc). The cable connects to a round flapper door on the back of the heater. If you pull cable knob out AND heater motor elec switch is in one of the reverse air flow settings, heated air is routed up two flex tubes to the defroster outlets on bottom edge of windshield. I understand (dealer installed options) 2 or 3 types of heaters were offered in 1947 and mine appears to be the most common. Used as a defroster, mine works so-so. Takes a while to heat up the windshield glass. As a heater, it works very well - has three outlet doors on front. Last edited by Drbrown; 01-30-2018 at 10:50 AM. |
01-30-2018, 11:10 AM | #3 | |
I believe this is the panel your looking for and there is one on eBay right now with the switch and cables. We use them for the hotrods and mount under the dash for controls with out drilling extra holes in the dash
Wanted Roadster Pick up thank you COLOR] |
01-31-2018, 10:41 AM | #4 |
Thank you for your reply that is what I needed, as I had no Idea what the second knob was for.
I will look for the bracket and both knobs. Thanks again |
01-31-2018, 10:53 AM | #5 |
They also have the two hole under dash mount
01-31-2018, 02:50 PM | #6 |
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand https://www.fordbarn.com/forum/album.php?albumid=580 |
11-25-2018, 10:16 AM | #7 | |
Sounds like we have the same heater and control knob |
11-25-2018, 11:50 AM | #8 |
Here's another.
05-05-2019, 02:37 PM | #9 |
My 47 Monarch (made in Canada ) has the same controls for the heater
05-05-2019, 03:02 PM | #10 |
That bracket is for the fresh air heater, that type has a snorkel that fits inside the hood to collect fresh air from in front of the radiator. The bracket you need only has two holes, 1 for the switch and the other for the defroster cable.
05-05-2019, 03:29 PM | #11 | |
I have the Fresh Air Heater fitted. I got the bracket with the 3 holes. Centre one for switch, one for defroster cable, the other for??? Phil NZ |
05-05-2019, 04:57 PM | #12 |
I think the other controls the fresh air flow from the snorkel.
05-05-2019, 06:49 PM | #13 |
Here is a picture from a file that shows the heater controls in a '46 sedan. The truck is likely a different style, but this will give you an idea of what Drbrown described. Thanks to Drbrown's description, I now know what is missing from my heater control. The defroster cable assembly. Anyone have one?
05-06-2019, 12:08 PM | #14 |
41 3 door heaters had the defroster control on the heater box like a 39/40 so did not require a two hole control panel. there is a one hole underdash panel like the two/three hole ones.
