Old 12-04-2020, 04:17 PM   #1
30-9
Default Bolt remover socket
Hi Gents
Another stripped bolt....ugh
Thinking about buying ABN bolt and nut remover sockets. Anyone have? Anyone suggest a reasonable priced set?
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 12-04-2020, 05:23 PM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: Bolt remover socket
If you've got the room, a pipe wrench. If not, a jacobs chuck, Or homedepot, lowes and amazon have extractor socket kits for about $25. Jack E/NJ
Old 12-04-2020, 05:37 PM   #3
30-9
Thanks - No room for pipe wrench. The ABNs are on Amazon.
Trying to determine if they work or if someone here has a set and recommend
Thanks - 30-9
1939, 1940
Old 12-04-2020, 07:05 PM   #4
banjoQ
banjoQ's Avatar
I have and have used extractor sockets. I would say they have a 50% success rate with me. Be sure to use all the tried and true methods first. Heat would be my first attempt, striking the bolt head with a hammer and drift to break up any corrosion. Then heat it up again and tap on the extractor socket. Gently try to back it out being careful not to break it off. Have had some success with an impact wrench, short blips. Other then that, soak it with a good penetrating oil and repeat. Remember that too much muscle usually results in snapping it off. Good luck.
banjoQ is offline   Reply With Quote
Old 12-04-2020, 07:21 PM   #5
JSeery
JSeery's Avatar
I'm with banjoQ, it sorta depends on what you are working with. Sometimes they work and sometime not. Rusted in studs or bolts are hard to remove with just an extractor of any kind. You really need something to break the rust bond, like the weld method. Anything that exceeds the bolt/stud strength is going to break bolt/stud again.
Old 12-04-2020, 07:40 PM   #6
30-9
Ok thx. I’m in no rush. I don’t know how to weld. I’ve been pb blasting, torch and vise grips. Just don’t want to round it anymore than it is. I’ll try again tomorrow and if no luck I’ll order ABN.
Thanks - 30-9
1939, 1940
Old 12-04-2020, 07:59 PM   #7
FL&WVMIKE
FL&WVMIKE's Avatar
What size is it? Sometimes you can pound on a metric socket that is just a tad smaller. Have you tried a 6 point socket? Impact wrenches are FAR more successful at busting loose stubborn nuts/bolts if you haven't already rounded them off.
Be sure to use proper form... Socket on STRAIGHT, and pulling straight/square while supporting the head of the ratchet.
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn.
FL&WVMIKE is offline   Reply With Quote
Old 12-10-2020, 09:15 AM   #8
old31
What about something like this. I have used it many times and it worked out well.
https://www.amazon.com/ARES-70016-Da...NsaWNrPXRydWU=
old31 is offline   Reply With Quote
Old 12-10-2020, 10:02 AM   #9
rockfla
rockfla's Avatar
"Sometimes".......you can try tightening the bolt "Slightly" and that will help break the hold of it, then loosen it.....at this point what do you have to loose....PLUS the tighten side of the flats are "Less" buggered up than the "loosen" side!!!
rockfla is online now   Reply With Quote
Old 12-10-2020, 10:56 AM   #10
1948F-1Pickup
1948F-1Pickup's Avatar
Might not have the luxury of doing this but I've cut mangled bolt heads off and welded on a nut..... if the bolt head is flush, you won't be doing that though.
1948F-1Pickup is offline   Reply With Quote
Old 12-10-2020, 12:20 PM   #11
Tim Ayers
Heat is also your friend. If you don't have a torch set, a MAPP gas set from Home Deport is pretty cheap and can get it some what hot enough to loosen the grip of rust. Repeated heating and cooling helps to loosen bolts. I also wick wax along the bolt while it's still red hot.
Tim Ayers is online now   Reply With Quote
Old 12-10-2020, 02:31 PM   #12
frnkeore
frnkeore's Avatar
If I'm getting this right, the hex of the bolt head is rounded, until a socket spins on it?
If that is the case, the way that I go about it, is to use a prick punch and a hammer to turn it. It usually works, if the bolt isn't to rusted on the threads.
Make a indentation, at the outer edge of the bolt head first. Then, with sharp, hard blows, drive it CCW, until it will turn by hand or pliers.
I'm surprised I don't hear this method mentioned on this forum. It's a old mechanic/farmer method I learned from my mechanic dad, when a teen and have used it in this way and flush, broken bolts and suds.
Sometimes, it's the only way to tighten a bolt, too.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 12-10-2020, 04:43 PM   #13
Jacques1960
Jacques1960's Avatar
++ on red wrench / linear impact / PB combo
No job’s done ‘til it’s all done
Jacques1960 is offline   Reply With Quote
Old 12-10-2020, 11:31 PM   #14
JSeery
JSeery's Avatar
Works well if the bolt/nut (I tend to use this method more on nuts) are large enough and it a location you can get good access to.
Old 12-11-2020, 04:41 PM   #15
Yoyodyne
Yoyodyne's Avatar
Chisels work too. A couple blows on a sharp cold chisel next to the corner, then use a blunt square ended chisel to continue without cutting the corner completely off. We be crude n'stuff, but sometimes it will get you home. If you ever see a nut that's all chiseled up, this is probably what happened. Especially a large one. Sometimes you can just sharpen the corners enough to get a socket to grab again.
Yoyodyne is offline   Reply With Quote
Old 12-11-2020, 06:07 PM   #16
aussie merc
aussie merc's Avatar
have a hunt thru your local tool store there are sockets made to do exactly this , for want of a better description an easy out that work on the outside the exact name escapes me but they do work and they grip tighter they more you turn
aussie merc is offline   Reply With Quote
Old 12-11-2020, 06:19 PM   #17
RKS.PA
RKS.PA's Avatar
In one of Mart's videos, he used a "stud remover" that clamps over the bolt and attaches to a 1/2 socket bar. Looked pretty handy to me so I bought one but haven't had a need to use it yet.
It tightens down on various sized studs and bolts, so it can be used for more than just a single size.
RKS.PA is offline   Reply With Quote
Old 12-11-2020, 07:51 PM   #18
swedishsteel
Take a cold chisel and hammer and split the nut, either from top or side. Works every time.
swedishsteel is offline   Reply With Quote
Old 12-12-2020, 02:32 PM   #19
JSeery
JSeery's Avatar
Or use a nut splitter if you are wanting to go that way.
Old 12-12-2020, 08:30 PM   #20
Graeme / New Zealand
Graeme / New Zealand's Avatar
I've got one of these sets of sockets to deal with rounded off bolts. You should be able to get these at any hardware store. Looks expensive but that because this is in NZ bucks.
https://www.bunnings.co.nz/irwin-8-p...r-set_p6320764
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
