Old 07-31-2021, 08:37 AM   #1
jtminor
Default 49 F1 Clutch problem
Just brought a 1949 Ford F1, like new condition 44,000 mile only two owners
But the clutch will not engaged, owner said it was good just a short time ago.
Looking for guidance to fix this problem.
Thanks for your input.
Jim
jtminor is offline   Reply With Quote
Old 07-31-2021, 08:45 AM   #2
marko39
Default Re: 49 F1 Clutch problem
The first thing I would check is the linkage to make sure nothing is disconnected.
marko39 is offline   Reply With Quote
Old 07-31-2021, 10:36 AM   #3
19Fordy
19Fordy's Avatar
Also, remove the transmission inspection plate and observe the throwout bearing when you actuate the clutch.
Old 07-31-2021, 10:46 AM   #4
Bob C
It won't engage or it won't disengage? In other words if the engine is running
you cant get the transmission into gear or you have it in gear and the truck
won't move when you let the clutch pedal out.
Old 07-31-2021, 11:02 AM   #5
Ken hash
Ken hash's Avatar
Here are some attachments that show clutch assembly and adjustment instructions. I hope this helps. Good luck.
File Type: jpg 2852AAA9-85B8-4AA5-AD0F-1EC2F810C915.jpg (57.0 KB, 23 views)
File Type: jpg A5AE6D68-6F1C-41FB-88C6-D862F7E7BB36.jpg (60.9 KB, 19 views)
Ken hash is offline   Reply With Quote
Old 07-31-2021, 11:25 AM   #6
19Fordy
19Fordy's Avatar
Can you remove the transmission cover and see what's going on inside the transmission regarding the shifting forks, etc? Is there fluid in the transmission?
Wonder what "a short time ago" really means? Reminds me of "ran when parked".
Old 07-31-2021, 03:23 PM   #7
Tim Ayers
Sadly, but exactly.
Old 07-31-2021, 07:04 PM   #8
jtminor
with engine running can not get into gear
Old 07-31-2021, 07:05 PM   #9
jtminor
Truck was driven within the last 30 days.....
Jim
Old 07-31-2021, 08:00 PM   #10
Bob C
If the free play and pedal feels good probably the clutch disc is
stuck to the flywheel, not really that uncommon.
Old 07-31-2021, 09:52 PM   #11
tubman
tubman's Avatar
I had this same problem with my '51 when I stored it for a couple of years. We took the car out on a deserted road in neutral. put it in gear and push started it. It broke free quite quickly.
Old 08-01-2021, 05:33 AM   #12
FortyNiner
FortyNiner's Avatar
Yup, start with the simple stuff.
Old 08-02-2021, 10:52 AM   #13
Als48
Put it in high gear and hold the brake. Then try to start it. That will quite likely unstick the disc.
Al Hook
Als48 is offline   Reply With Quote
Old 08-02-2021, 02:10 PM   #14
1948F-1Pickup
1948F-1Pickup's Avatar
..... the clutch disc is
Interesting. I've been driving manual vehicles since 1976 and
I've never experienced this.
Just lucky I guess.....
1948F-1Pickup is offline   Reply With Quote
Old 08-02-2021, 02:12 PM   #15
tubman
tubman's Avatar
When it happened to me, the car had been stored in an unheated garage in Minnesota for 3 years.
Once it freed up, it worked like it had before.
Old 08-02-2021, 02:39 PM   #16
40cpe
40cpe's Avatar
It happens to vehicles stored in humid area with the clutch pedal up. I found on my tractor that If i block the clutch pedal down for a few days it allows the disc to relax and it breaks loose easier.
Old 08-03-2021, 08:41 PM   #17
jtminor
So far no luck in freeing clutch and flywheel... just keep trying the many suggestion,
Thanks everyone for your helpful input.....
Jim - WI
Old 08-03-2021, 10:13 PM   #18
cas3
I've had a few stuck clutches on the near dead junk I drag home. If it runs, I go out on the gravel road I live on in first gear, hold the clutch pedal to the floor and stomp on and off the gas pedal to get as much violence happening as you can. Usually works. If it doesn't run, I will park it on the hill in my driveway, in first gear, clutch in, and rock it back and forth with the bobcat pushing up, gravity pushing down, and again, as much violence as you can make. the slop in the drive train sorta acts like an impact gun when the play is used up, it gets a hit
Old 08-04-2021, 12:24 PM   #19
jtminor
Any suggested tricks in removing trans inspection cover....
Thanks
Old 08-04-2021, 12:44 PM   #20
Ross F-1
Ross F-1's Avatar
The clutch inspection cover is shown below; there is no trans inspection cover. What exactly do you mean?
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
