Old 07-06-2021, 09:33 AM   #21
Bill Wyckoff
Default Re: 1939 ford steering lock stuck
TJ sorry I can't private message as they say I'm "new" and haven't posted 10 times. At 75 I'm glad they think I'm new
Bill
Bill Wyckoff is offline   Reply With Quote
Old 07-06-2021, 09:34 AM   #22
deuce lover
deuce lover's Avatar
Originally Posted by Bill Wyckoff View Post
The chrome button on mine is flush and won't move. I have photos I can send.
Thanks,
Bill
To help you see how it functions Here are 2 pics I just took of what the mechanism is like and lock cyl in correct position.The knurled end of the mechanism is where the chrome button is pressed on.The button on opposite end is spring loaded. The first pic is in the locked position and the key can be removed-it is pulled out slightly to show you..The 2nd pic is the unlocked position and key will not come out.You can see by the slot for the lock cyl locates differently.
Old 07-06-2021, 09:50 AM   #23
Bill Wyckoff
My lock has been removed and the cyl works fine after being removed. I just thought it was bad as it would only turn a few degrees and wouldn't release the steering lock.
Bill
Old 07-06-2021, 10:40 AM   #24
JSeery
JSeery's Avatar
Email your photos to me, and I will post them for you. jseery@ymail.com
Old 07-06-2021, 01:38 PM   #25
JSeery
JSeery's Avatar
Bills lock photo.
Old 07-06-2021, 02:00 PM   #26
deuce lover
Maybe if he removes the switch on the back could help.
Old 07-06-2021, 03:01 PM   #27
Bill Wyckoff
Thanks, I have the switch box off the back. Thinking about removing the switch plate on front, but the pins are almost flush and leave no room to grab. Hate to mess it up.
Bill
Old 07-07-2021, 02:23 PM   #28
deuce lover
I never have encountered one as stubborn as yours. The mechanism is seriously stuck.There might be a member here that can post an illustration of the breakdown of the assy.Removing the On- Off plate won't really help.Its held in by those 2 twist in rivets. I use a very small (2.5")vise grip to grab it and turn counter clockwise-they come right out.Sometimes filing a small flat spot on 2 sides is necessary but then the rivet won't look right if reused.
Old 07-07-2021, 03:24 PM   #29
Bill Wyckoff
Thanks, I was working on it again last night and took a photo of the back side. I sent this to JSeery to post as I don't seem to get that to work. From the back side you can see the button and it won't move.
Bill
Old 07-07-2021, 03:48 PM   #30
JSeery
JSeery's Avatar
Bill
Nothing showed up, did it get sent to the correct email address?
Old 07-07-2021, 04:45 PM   #31
Bill Wyckoff
I tried sending it again.
Sorry,
Bill
Old 07-07-2021, 04:53 PM   #32
JSeery
JSeery's Avatar
Funny, both emails showed up at the same time! Anyway, here is the photo.
Old 07-08-2021, 10:09 AM   #33
TJ
TJ's Avatar
I suspect the chrome end cap has a lot of corrosion between the cap and the cast iron housing. Have you tried PB Blaster?
Old 07-08-2021, 10:21 AM   #34
Bill Wyckoff
I've tried PB Blaster, even covering the lock so it could soak. Also many other products. It just won't move. I am thinking about removing the column so I can get a better angle to trying whacking on it while on a work bench. The corrosion angle could be it. It isn't in a very good place now to apply heat.
Bill
Old 07-08-2021, 11:19 AM   #35
tubman
tubman's Avatar
If there is a significant amount of steel in the assembly, I would consider soaking it in a vat of Evaporust.
Old 07-08-2021, 11:29 AM   #36
Bill Wyckoff
Thanks, I'll try that tonight.
Bill
Old 07-08-2021, 11:30 AM   #37
deuce lover
Since its in the locked position it going to be difficult to remove the column.That spring loaded button in pic of post #22 is engaged in the locking collar .There are 2 screws securing that collar to the steering shaft.
Old 07-08-2021, 12:35 PM   #38
cas3
If the steering wheel was off, would the tube have enough slop to pull off? Seems to me the pin sits in a slot with a rolled up edge to prevent it from turning, but not necessarily from sliding up or down. going off memory here, I dont have one apart to look at
Old 07-08-2021, 01:02 PM   #39
TJ
TJ's Avatar
The end cap is what is holding up the assembly from coming loose. The end cap is die cast. At one time someone reproduced the end cap. Search around and if you can find another end cap I would then then drill a series of holes in the cap and slowly chisel and break it out.
Old 07-08-2021, 03:39 PM   #40
Bill Wyckoff
Thanks, if the Evaporust doesn't work, I'll try this before tearing out the column.
Bill
