Old 01-13-2015, 09:22 AM   #1
donald1950
Default 1953 motor swap
i have a high milage 1953 Ford 4 door with a ford-o-matic. I will be replacing a much lower milage motor in a 2 door Victoria with a manual transmission with a new motor. i am considering replacing the smokey, low compression high milage motor in the 4 door with the low milage normal compression non smokey motor coming out of the 2 door car.
is there a difference in crankshafts between the auto and manual trans motors? will all i have to do is bolt everything back together?
i intend to keep the 2 door as it is a beautifull restored car, the 4 door is rougher but a great handeling/driving car that i will keep for several more years and would like to take on an occasional long trip. the auto transmission has been rebuilt and is in excelent shape.
is there anything i need to be aware of to start this adventure??
thank you for any and all help.... don
donald1950 is offline   Reply With Quote
Old 01-13-2015, 09:37 AM   #2
Vic Piano
Vic Piano's Avatar
Default Re: 1953 motor swap
There is a difference between the crankshaft in a motor that was originally matted to a Ford-O-Matic. I think (CRS) that the crankshaft in an automatic transmission motor has an indentation to accommodate the torque converter. I'm sure there will be others who can elaborate on the various differences.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 01-13-2015, 09:45 AM   #3
rotorwrench
rotorwrench's Avatar
Vic has it. The recess in the back of the crank allows for the torque converter but will not interfere with the manual transmission flywheel/clutch installation.
Old 01-13-2015, 09:48 AM   #4
Blu Dice
Blu Dice's Avatar
Need of a pilot bearing?????
4 doors are better than no doors!
Blu Dice is offline   Reply With Quote
Old 01-13-2015, 09:49 AM   #5
rotorwrench
Pilot bearing fits in the flywheel.
Old 01-13-2015, 09:49 AM   #6
Ol' Ron
Ol' Ron's Avatar
It depends on the year of the replacement engines. Most engines made from 51-53 have the right crank for both std and auto trans. Unfortunately, youwon't know till you pull the engine. Remove the flywheel and look at the back of the crank it will have a hole in it about 2" in dia about an inch deep. I take these dim from memory, had an auto in my truck last year.
Old 01-13-2015, 11:42 AM   #7
51 MERC-CT
51 MERC-CT's Avatar
Not being picky but if a hole that is 1.250"dia. is present, it's OK.
Old 01-13-2015, 08:58 PM   #8
donald1950
thank you all.. both motors are '53s.....
