Old 10-13-2017, 11:34 AM   #1
René W
René W's Avatar
Default Engine stalls at full throttle
"29 Tudor stock engine,when driving at full throttle afterv a short while the engine stops like it is getting no fuel,i step on the clutch and wait a couple of seconds and push the starter and it runs again.
When i am driving at slow speed there is no problem,only when the engine has to work.
My guess was a fuel blockage so what did i do?
Drained the fuel tank and cleaned it(no debri found)fueltank closing device(don't know the name in english)cleaned,fuel lines are clean,sediment bowl was full of rust,removed and replaced by a piece of fuel line,cleaned the carburettor.
When i open the tank with the carburettor disconnected the fuel pours out the lines like hell so there is no blockage at all.
Car was en is running great,nothing has chanched,i can drive all day but when is has to work it stalls,anyone got an idea?
It is a pile of shit bit it's my pile of shit
René W is offline   Reply With Quote
Old 10-13-2017, 11:48 AM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: Engine stalls at full throttle
Is your fuel cap venting? might be partially plugged. Get it to act up, pull over and loosten the cap and drive the same stretch of road and if the problem no longer exists id clean the fuel cap.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 10-13-2017, 11:53 AM   #3
René W
René W's Avatar
Fuel cap is venting for sure,it has a 2mm hole drilled tru and i can see the whole world thru the hole
Old 10-13-2017, 12:26 PM   #4
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Sounds like the classic problem of the fuel line pushed too far into the carb. The end hits the screen and the flow area is only the small openings within the ID of the tube. It probably won't go up a hill. Give it a circumcision of about 1/8 in.
Jacksonlll is offline   Reply With Quote
Old 10-13-2017, 12:33 PM   #5
steve s
steve s's Avatar
If you have a fuel filter, remove it.
Are you sure your timing is set correctly?
Steve
steve s is offline   Reply With Quote
Old 10-13-2017, 12:38 PM   #6
Mikeinnj
Mikeinnj's Avatar
If the float valve is set too low the gas level in the main jet and cap jet will be too low and it will be difficult for the gas to be drawn out, causing the combustible fuel supplied to the engine to be lean.
Mikeinnj is offline   Reply With Quote
Old 10-13-2017, 01:03 PM   #7
René W
René W's Avatar
I will check tomorrow.
No filter
Timing is correct,engine runs beautiful.
Did not chance the float level,never had this problem before,it just came up a couple of days ago.
At first i thought it was a timing issue,cleaned the points,set the gap,set the timing using a test light,have a blue spark you can weld with,engine starts at first turn............it only stalls when it has to work,that is using all horsepower there is.
Accellerating from 0 to 90km/h in one run......it stalls before 90km/h is there
Old 10-13-2017, 01:14 PM   #8
JDupuis
JDupuis's Avatar
René, are you fully advancing the timing at full throttle?
If so, next time retard the timing a bit. Might be a loose connection at the short wire in the distributor. ( under the points plate)
Had this happen to me on one of my cars. Loose nut on the wire, and a loose nut behind the steering wheel! . Good Luck! Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 10-13-2017, 01:48 PM   #9
René W
René W's Avatar
Jeff......could be the problem,check tomorrow
Old 10-13-2017, 02:30 PM   #10
steve s
steve s's Avatar
What is different at full throttle is that the cylinders are taking in the maximum charge of air/fuel mix. That increases the pressure in the combustion chamber, and makes it harder for a spark to jump the spark plug gap. The voltage upstream of the plug will then build to a higher level and try to jump to ground via an alternate path that it might not ordinarily utilize.
Check the spark plug gaps and clean the ceramics. Inspect/clean/replace the coil and distributor cap/body/wiring. These are things that could have changed without you doing anything. However, I would also expect some backfiring.
Old 10-13-2017, 02:53 PM   #11
George Miller
George Miller's Avatar
I would try a new condenser.
George Miller is offline   Reply With Quote
Old 10-13-2017, 11:25 PM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
Did you clean the filter inside the carb?
Old 10-14-2017, 06:28 AM   #13
DJ S
DJ S's Avatar
I had a similiar problem. It was a bad condenser.
DJ S is offline   Reply With Quote
Old 10-14-2017, 07:34 AM   #14
René W
René W's Avatar
For now you are right.
The fuel line was way to deep into the carb but because it is a battered line and plug i just ordered a new fuel line,i hope that solve the problem.
I also re-checked the ingnition system but could not find any problem there,if the condenser is bad i will find out when the fuel line is mounted and the problem is still there.................i.ll be back!
Old 10-14-2017, 08:02 AM   #15
Jacksonlll
Jacksonlll's Avatar
Just make sure you put the ferrule near the end of the fuel line. Don't hit the screen.
Old 10-14-2017, 09:00 AM   #16
René W
René W's Avatar
do i need to solder the ferrule?
Old 10-14-2017, 09:12 AM   #17
Ray64
Ray64's Avatar
No you don't have to solder
Ray64 is offline   Reply With Quote
Old 10-14-2017, 10:07 AM   #18
100IH
When you tighten the nut, it will squeeze (crimp) the ferrule so it will grab the tube. If you get a female threaded fitting, you will be able to see how much is extended past the ferrule as you tighten.
100IH is offline   Reply With Quote
Old 10-23-2017, 02:59 PM   #19
René W
René W's Avatar
Problem solved..............
i installed a new Original fuel line from the bowl to carb to replace the rubber fuel line,installed new points and condenser and the problem is gone,it must be a bad condensor.......Happy now,thanks for the tips
Old 10-23-2017, 04:43 PM   #20
100IH
Or it could be the fuel line, Good practice is to do only change at a time with test drive between changes. That way you will always know the real answer. Feedback is the best teacher.
