Old 09-15-2020, 10:39 AM   #1
Jrappl
Default 1959 generator and voltage regulator capacitors
I'm restoring a 1959 Edsel Ranger 292/auto. The generator and voltage regulator have what appear to be capacitors hanging on them. Are these just for radio noise suppression and can I run without them?
I can't find mention of them anywhere including the factory Edsel shop manuals and there are no markings on them to be able to match them up.
Jrappl is offline   Reply With Quote
Old 09-15-2020, 11:42 AM   #2
dmsfrr
dmsfrr's Avatar
Default Re: 1959 generator and voltage regulator capacitors
Yes they're for radio noise suppression. Chances are good they may also help to reduce sparks and arcing on the commutator and relay contacts. But it's been too long since that electronics class... ???
Old 09-15-2020, 07:50 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
Yes, they're mainly for radio noise suppression. I have never found what the capacity of the original condensers was, so kind of hard to replace, even if you could get a new one that doesn't look like the old one.
Years ago I converted a '55 to 12-volts and installed a modern AM/FM stereo. I added a noise suppression capacitor from Radio Shack ahead of the power feed to the radio and threw away the old condensers.
