01-03-2019, 10:26 PM | #1 |
NAPA thermostats 180 degrees
I have the subaru 170 degree napa thermostats #111 in my woodie (3 1/16 replacement block) right now. This weekend I plan on installing an arvin heater I found at a swap meet. I have gotten everything purchased to do the job and the heater is all cleaned up. I was just hoping there is a napa thermostat that's 180 degrees for a bit more heat and maybe less sludge. Their books here don't go past 1951. Tomorrow being friday I was just hoping someone would say something such as '1972 ford granada' or 1971 toyota hilux and it would have the same diameter disc etc....
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
01-03-2019, 10:45 PM | #2 |
Re: NAPA thermostats 180 degrees
Stant makes most of the radiator caps and thermostats. We used them at work for thirty-year's and they seamed to be as good as the originals. Here is a link to the Stant vintage catalog. If you know the model Subaru your 170 thermostat came out of there might be 180 degree option listed for the same car. Napa should be able to crossover the number.
http://www.stant.com/files/2714/0979...tage_Guide.pdf |
01-03-2019, 11:11 PM | #3 |
Just checked it... It's for a 1990-1994 subaru justy 1.2 liter. Haven't been able to see what the specs are, but for my 221 cu in, and split in half, seems about right. I think the diameter of the disc portion is key. Not like it's 20 below here, so the existing 170 degree stats ok, but the woodie is still pretty drafty with no door weatherstripping in place, and when we get a sunny winter day the two of us and the dog may want to go to the dump 'styling'. Draining the system to re-do the stats in the spring is always an ordeal too, but heck, that's four months from now
01-04-2019, 01:19 AM | #4 |
For a temporary increase in the operating temperature during cold times of the year the simplest thing to do is to place a piece of cardboard or similar material in front of the radiator.
Generally 30% to 50% coverage will do the trick. Just monitor and adjust amount of coverage that is required. Beats having to do an annual thermostat change.
01-04-2019, 04:06 AM | #5 |
And if going for a winter only thermostat...atleast around here we used to install 195F+ stats.
If you check NAPA they have the Subaru stat from 170-195F. The cardboard trick is great....still doesn´t raise the watertemp to the heater if that is what you need to inrease heating capacity. |
01-04-2019, 05:43 AM | #6 |
01-04-2019, 06:18 AM | #7 |
If you need more energy then available with a 170F stat...raising the working temp of the engine makes more energy available at the heater core.
Partly blocking the radiator can only get you up to the working temp of the installed stat in a safe way... |
01-04-2019, 06:32 AM | #8 |
That's strange because I am running a 160°F thermostat and with the addition of partial radiator blockage the water temp. runs in the 185°F range and the difference is felt in the heater also.
01-04-2019, 06:50 AM | #9 |
Usually letting something else then the thermostat control the engine working temp...restricting flow of either water or air is less safe...not saying it can´t be done.
And my original point was if OP needed more heat in the cab go for a winter stat. Feels like it´s time to ask what oil he´s running |
01-04-2019, 07:35 AM | #10 |
My .02 .... i run n a p a 180s in my 8ba. Never goes over 185 in the heat of summer & like 51 merc i put cardboard in on cold days & it gives me more heat in the car. m
01-04-2019, 07:41 AM | #11 |
I have used material to block the radiator as well. I think the point is it is more difficult to regulate than using a thermostat.
01-04-2019, 08:00 AM | #12 |
Until the 1930's when the first automotive thermostats started to be used, the primary attempts at temperature control were controllable slats in front of the radiator such as the much coveted Pines Winterfront grille.
01-04-2019, 09:29 AM | #13 |
And these methods were replaced by thermostats. Not sure what the problem with thermostats is, but as I posted, I grew up blocking radiators to get an engine to heat up in the winter. Just easier to use good thermostates.
01-04-2019, 10:00 AM | #14 |
They can get you an Altrom 180 degree version which is made by TAMA. TAMA is an oem supplier to Subaru. The problem is that the closest pair available is getting 1 from Portland and 1 from Spokane. part # 154-3601
01-04-2019, 11:53 AM | #15 |
Or you van order full flow thermostats from Bob Shewman in Pa in 160 or 180.
01-04-2019, 01:23 PM | #16 |
Thanks all ! I'll be at napa this afternoon after work and see what they have. If it had been in their books, is there a napa part # for a '46 V8 180 degree thermostat? I know I could order something, but tomorrow is just a good day for me to perform the operation, that's all. We're a one horse town here for auto parts.
01-04-2019, 04:03 PM | #17 |
GB, a 46 would not have a modern style thermostat, it would use the older "barrel" type that mount up by the top inlets to the radiator. You need a diameter that will fit into the hoses at the outlet on the heads. You then need to use a method to secure them. There was a post a week or so ago where I listed all of the numbers and models they were from that will fit.
https://fordbarn.com/forum/showthrea...ght=Thermostat Post #4 & #25 Last edited by JSeery; 01-05-2019 at 10:56 AM. |
01-05-2019, 06:19 AM | #18 |
with Offy head on a 59ab the therms dont fit without grinding the id of the heads.What thermostat ft without grinding.Mine doesn't get hot enough to use the Vintage air heater.It is a heater by itself no A/C
01-05-2019, 10:44 AM | #19 |
I've always had a problem with keeping the thermostats from flipping sideways on my 40. Thinking about using JB Weld to glue them down. Some use wire or smaller id hose to hold them but never had any luck doing this. What do you guys do?
Phil Swanson |
01-05-2019, 12:29 PM | #20 |
There was a t/stat thread a week or so ago with pics of how Ol'Henry wires them in. FWIW
Paul in CT |
